S70 Speakers Demystified
I posted earlier asking about recommended speaker sizes to replace the blown speakers in my daughter’s S70 and the response was pretty much crickets. I had to make a couple of trips to the local Pick & Pull for some other parts so I tried to pull the speakers from a donor S70 while I was there but they were rotted as well. The foam on the edges of the cones had basically turned to dust on all of them in the lot. I pulled a speaker for each door and a rear deck speaker anyway, I think the Pick & Pull just gave them to me or charged very little for them since they were bad anyway and I was buying a bunch of other stuff. I figured having them would let me experiment on fitting other speakers into the frames.
S70 speakers
S70 speakers demystified.
Forum views 4658Forum replies 8
Date July 29, 2013
2 responses to “S70 Speakers Demystified”
  1. Eric C says:
    Hello depending on how astute you are at making speaker repairs you could always try ebay for new foam speaker rings. They would be a cheap fix with minimal work of gluing the new rings in place aslong as the cones and coils are still good and have not been over extended.
    Hope this helps you.
  2. James says:
    There are speaker rebuild kits.
