April 29, 2009
S80, 2001+ V70, XC70, S60 Oil & Filter Change Tutorial
The pics are of my 2001 S80 T6 but the procedure should apply to other P2 cars as well.
Tools and supplies you will need: Jack and jackstands, 12mm socket and ratchet, Oil Filter Wrench (band type or special Volvo tool), 17mm socket and ratchet or 17mm end wrench, Oil drain pan, New filter with o-ring, New drain plug aluminum crush washer (optional but recommended), 7 quarts of oil (for a T6 – others may take less), Paper towels or rags, Funnel, Small screwdriver, Torque wrench.
Volvo S80 Oil and Filter Change How-To Tutorial
One response to “S80, 2001+ V70, XC70, S60 Oil & Filter Change Tutorial”
  1. […] (Cap & rotor tutorial: Volvo 850 & S70, V70, XC70, C70 up to 1998*) oil/transflush (Oil change tutorial: Volvo S80, S60 & V70, XC70 2001+) (Oil change tutorial: Volvo 850 & S70, V70, XC70 up to 1998*) filter (oil) hoses (the […]
