Volvo Repair Database
S80 Parking Brake Adjustment
Does your parking brake handle come up way too high when you apply it? Does it not engage even when you pull the handle all the way up? Here’s how to adjust it. You will need a flat-bit screwdriver and a 10mm or adjustable wrench.
How to adjust the parking brake on the 2001 S80 T6. May apply to other years and normally aspirated models.
(Looking for a tutorial on changing S80 regular brakes? Click here for an Volvo S80 Rear Brake Pad & Rotor Change.)
  1. How To Replace E-Brake Pads
  2. V70XC Hood Latch Adjustment
  3. S80 Front Brake Disk and Pad Replacement
  4. Brake Shims Fix 850, S70, V70, XC70 Squealing & Noise
  5. Replacing Front Brake Discs & Pads
This entry was posted in Brakes, Brake Fluid, Brake Lines, Brake Pedal, Parking Brake, Pads, Rotors, ABS, TRACS, Volvo S80 and tagged , , , , . Bookmark the permalink.
