Is it the ABS module or the wheel sensor? Hopefully this will clear things up a bit for you.
Speed sensor A – (error code P0500) Help!!!
I am having trouble with the speed sensor, code 0500. My speedometer will sometimes quit and the fault will light the check engine light as well as the trany fault light. I can clear it and it will return after a while. The speedometer usually restarts after driving a short time. Appears to be a random fault that sets stops the speedometer when in failed mode then corrects itself restarting the speedometer. I replaced the rear speed sensor in the differential with a good used one, but it did not improve the problem. Any ideas?
