Volvo Repair Database
Brake Calipers Dragging? Replace Them?
I could not afford the calipers so I decided to re-lube the pistons on the calipers and guide-pins using CRC-synthetic brake & caliper grease in the hopes that the guide pins might have been sticking and causing the drag.
  1. How To Replace E-Brake Pads
  2. Brake Pad and Rotor Job Checklist & Tutorial
  3. Brake Shims Fix 850, S70, V70, XC70 Squealing & Noise
This entry was posted in Brakes, Brake Fluid, Brake Lines, Brake Pedal, Parking Brake, Pads, Rotors, ABS, TRACS, Volvo 940, 960, S90 & V90 and tagged , , , . Bookmark the permalink.
