Volvo Repair Database
Brake Pad and Rotor Job Checklist & Tutorial
  1. remove tire
  2. remove the spring clip on the caliper
  3. remove the caliper (7MM hex socket required; remove the caps & the 7MM hex bolts that hold the caliper) …
  1. Brake Shims Fix 850, S70, V70, XC70 Squealing & Noise
  2. 850 and V/S70 Shock Change Checklist
  3. Replace Trunk Struts Tutorial
  4. Increase Performance: Horn Relocation
  5. Front Driveshaft Remove + Replace
This entry was posted in Brakes, Brake Fluid, Brake Lines, Brake Pedal, Parking Brake, Pads, Rotors, ABS, TRACS, Volvo 850, Volvo C70, Volvo S70 & V70, 1998-2000, Volvo XC70 & V70XC and tagged , , , . Bookmark the permalink.
