Volvo Repair Database
Tag Archives: AC shim
A/C clutch shim procedure for S60
S60 AC Clutch Shim Instructions Here’s the now famous DIY procedure to fix your air conditioning by shimming the AC clutch, but for the Volvo S60. If your AC blows cold for only 5 minutes, and you’ve recharged the R134a, … Continue reading
5 Comments
A/C Compressor Shim Fix: Bread Clip
So, I am fairly sure my car is having an issue with the compressor disengaging and then not re-engaging when it should. I am not sure if anyone else has heard about the bread clip shim fix, but I am … Continue reading
9 Comments
Volvo Air Conditioning Problems and Fixes
Air conditioning problems? Start here. Continue reading
32 Comments
