Tag Archives: antenna mast
850 Power Antenna Removal & Repair
Step-by-Step how to Replace Antenna Since last winter I’ve been going without a power antenna, which often gave me little or no reception. I finally decided to tackle it. I’ve created a photo collage as best as I could, I … Continue reading
850 Antenna Mast Won’t Pull Out
Removing the Antenna Mast What to pull, what to push, what to yank, and when to give up and buy a replacement. 850 Antenna Mast Won’t Pull Out
850 power antena
I clean the mast from time to time, but the chrome is worn off one side. It is only a matter of time before a vital section of the plastic gearing [the spline?] breaks.
I replaced the mast in another car. It took about 45 minutes, and was a bit painful to get to, but $20 later, it worked fine. Continue reading
Register
Search
Help
