Volvo Repair Database
Tag Archives: bevel gear
How to change rear bevel fluid on AWD P2 Volvos
Tutorial – Change Bevel/Angle Fluid on AWD 2003+ Volvos Before proceeding with this tutorial, ensure that your Volvo AWD system is the same one as is on my 2004 V70 R. If it is, you’ll have no problem. If not, … Continue reading
Leave a comment
AWD issues – Diagonosing bad propshaft in XC70
AWD Center Carrier Mount Failure I was just about to reply that the center carrier mount was definitly causing your problem when you posted that you removed your driveshaft and found it out for yourself. I just went through this … Continue reading
Leave a comment
Bevel Gear Maintenance on 1997-2002 Volvo AWD Cars
Beveal Gear Maintenance Here’s a downloadable PDF from V70XC.com on how to change bevel (angle) gear fluid on 1997-2002 model Volvo AWD cars. For 2003+, you have a Haldex system, and it’s got an additional fluid to maintain. Unfortunately, no … Continue reading
Leave a comment
1999+ Transmission Fluid Caveat
[no comments] Continue reading
Leave a comment
