Volvo Repair Database
Tag Archives: brake lights
Volvo 240 Tailgate Chomped My Wires
A common problem on 240 estates (wagons) is breakdown of the wiring to the rear lights and heated rear screen due to bad design. The wiring runs around the hinge on the tailgate and eventually wears through. This is a … Continue reading
940 1993 Stop Lights Do Not Work
stop lights do not work when the brakes are applied I followed your advice and “zingo!” it worked perfectly. The Bulb Fault Relay was in fact the culprit, after removing the plastic cover on the cigarette lighter and the two … Continue reading
Leave a comment
