Volvo Repair Database
Tag Archives: Crankshaft Pulley
89 240 Crank Pulley Looks Unbalanced?
Crankshaft Pulley Vibration Damper Volvo call the pulley ‘an oscillation damper’ and the rubber insert is built in. The problem comes when the rubber stretches and allows the metal to move on its own. There is a possibility that the … Continue reading
Leave a comment
Crankshaft Pulley – Timing Belt – Poor Idle and Drivability
The recent struggles with my 740 revealed how the crankshaft pulley can degrade without obvious signs and how this degradation can affect drivability, curb idle, ignition timing and proper indexing of the crankshaft and camshaft sprockets during a timing belt … Continue reading
Leave a comment
Notes on Changing the Timing Belt
The only thing that’s a real PITA is getting the timing belt off of the crankshaft pulley and getting the new one back on, as there’s a tight squeeze. Continue reading
Leave a comment
