Volvo Repair Database
Tag Archives: driveshaft removal
Volvo V70 AWD – ‘Clanking’ noise when driving
The 1998-2000 AWD v70 use 3 different drive shafts. 1. early 1998 2. late 1998 – 1999 3. 2000 You need the VIN to figure out which drive shaft you have. Or you can measure the flange size. Volvo V70 … Continue reading
Leave a comment
AWD issues – Diagonosing bad propshaft in XC70
AWD Center Carrier Mount Failure I was just about to reply that the center carrier mount was definitly causing your problem when you posted that you removed your driveshaft and found it out for yourself. I just went through this … Continue reading
Leave a comment
