Volvo Repair Database
Tag Archives: engine mount
Volvo 940 Engine Mount Replacement Tutorial
MVS Contributor and Member Writer100 shows us how to do a Volvo 940 engine mount replacement — including, importantly, what parts to buy to save $68 per side. The local Volvo dealer quoted me $100 per mount. Volvo Parts Online … Continue reading
Leave a comment
Polyurethane upper engine mount gave extreme vibration
It is easy to twist the mount during install so pay attention to its position when you do, That will insure that no stress or movement of the mount will exceed its travel limit. 1) After tightening, The Washer’s edge … Continue reading
Leave a comment
Replace Upper Engine Mount w/ OEM Bushing
Upper Engine Mount Bushing Tutorial Overview By Geevs The 850′s upper engine mount is designed to hold the engine in place. Without it, the engine would thrash back and forth in the engine bay and damage nearly everything near it. … Continue reading
10 Comments
Replace Upper Engine Mount w/ Polyurethane Bushing
Bushing Replacement Tutorial Overview The 850′s upper engine mount is designed to hold the engine in place. Without it, the engine would thrash back and forth in the engine bay and damage nearly everything near it. There are two lower … Continue reading
8 Comments
S60 Poly Top Engine Mount
I have an’04 S60 and just replaced the top mount with the polyurethane mount from IPD. They warn of more vibration but couldn’t believe how much worse the vibration is. Think I’m going to swap this back out for the … Continue reading
