Volvo Repair Database
Tag Archives: fuel filter
Replace Fuel Filter on a Volvo 740 Tips
I recently changed out the filter on my 240 which has the same set up. I had the thing in and out about 5 times before I got it right. When you to get it out put that fuel line … Continue reading
Leave a comment
Fuel Filter Replacement DIY
This is a short DIY write up for the removal of a fuel filter on an 850. This is a very easy procedure, just remember to be safe — safety goggles, no open flame [despite the photo to the right], … Continue reading
How to change the fuel filter on a 2004 V70 (video)
DIY Fuel Filter Change on Volvo V70 This is one of the easier things you can do at home to maintain your Volvo. I was amazed at the simplicity of the quick release system on this filter. Here’s one of … Continue reading
Leave a comment
240 Fuel Filter Location & Dieseling Problem
B21F Engine – 240 Fuel Filter Location Disconnect the battery negative lead making sure that you have the radio code if applicable. In the luggage compartment lift the carpet and you will see an inspection plate in the floor. Remove … Continue reading
XC90 DIY: Oil, Spark Plugs, Air & Fuel Filters, Transmission Fluid Flush
Spark Plugs 1 – The turbo line that goes front to back will need to be removed. What I did was just remove the clamp ring towards the front of the line (because it is easiest to get to), but there is also one at the back. If you can do what I did, loosen the front clamp and pull the plastic hose out of the rubber. Continue reading
Change Fuel Filter Tutorial
[no comments] Continue reading
5 Comments
