Tag Archives: fuel injectors
850 N/a Throttle Body on a T-5 manifold for performance
Bigger Throttle Plate and Injectors for More Horsepower? Keep in mind that many of the N/A tricks do not apply as the turbo pressurizes the air and this offsets most intake restrictions. The main thing that occurs is that the … Continue reading
Cleaning fuel injectors
Searching on the internet I found a description of alternating sprays of brake cleaner and compressed air through the inside of the injectors. Would that work on our cars? Cleaning fuel injectors
Check Engine Light – Running Rough
Turned out to be 2 bad fuel injectors. Completely blocked, kaput. This would explain my mystery bogging/surging problem a couple of months ago, as they were starting to go then. Those things are expensive. Should have done more “Italian Tune-ups”. … Continue reading
Register
Search
Help
