Tag Archives: fuel pressure regulator
Fuel Pressure Regulator
Fuel Pressure Regulator Symptoms In addition to tackling codes this weekend, I recently noticed the smell gas inside and outside my 850. I popped the hood and noticed a slow leak from the fuel pressure regulator. I disconnected the vacuum … Continue reading
Due for PCV Job
Tips on doing the PVC on your 850, S70 or V70 “I have not removed the injectors on any of them. The only thing that is tricky is getting the fuel return line off since the hose is a little … Continue reading
Register
Search
Help
