Volvo Repair Database
Tag Archives: glove box
Fix a Stuck Glove Box Tutorial
Glove Box Fix By Yeagermeister Overview if you’re willing to put a small hole in the glove box instead of cutting the loop, this is how to do it. Procedure The measurements: 225mm from the right hand side of the … Continue reading
4 Comments
Compartment under glove box is broken
70 Series map tray / lower dash panel repair. A good writeup with pictures. Compartment under glove box is broken.
Leave a comment
Glove Box Repair # 3 – The Saw Method
The hardest part of the job is sawing through the catch hoop or, as Volvo calls it, the brace… Continue reading
Glove Box Fix #1 – The Small Hole Method
If you’re willing to put a small hole in the glove box instead of cutting the loop, this is how to do it… Continue reading
Leave a comment
Glove Box Fix #2 – A Hacksaw Method
My glovebox latch broke on my 93 850GLT. The door handle would not unlock the box. I did the hacksaw trick. I used two large thin metal puddy knoves on either side of the hacksaw to protect the vinyl… Continue reading
