Tag Archives: ignition cylinder
DIY 1998 Volvo V70 Ignition Switch & Cylinder Lock Replacement
Car is 1998 Volvo V70 with 106K miles. Symptoms: sometimes cannot crank the engine, after wiggling the key a few times, then I can start the engine. It was intermittent, then it became permanent. Key can turn to Position I … Continue reading
Ignition Tumbler Experience — Key Spins in Ignition
Volvo Keys – the difference between physical and coded/transponder Is this the right part number for my a car for a coded setup so I don’t have to have multiple keys? When I order it how do I make sure … Continue reading
Key Won’t Turn Past Position I
Ignition Won’t Turn Past Position I http://www.matthewsvolvosite.com/forums/viewtopic.php?p=97472#p97472 Having removed the plastic covers and electric bits away from the area, I chiseled off the metal plate at the bottom of the lock. I found a broken piece of casting inside but … Continue reading
Register
Search
Help
