Volvo Repair Database
Tag Archives: ignition switch
DIY 1998 Volvo V70 Ignition Switch & Cylinder Lock Replacement
Car is 1998 Volvo V70 with 106K miles. Symptoms: sometimes cannot crank the engine, after wiggling the key a few times, then I can start the engine. It was intermittent, then it became permanent. Key can turn to Position I … Continue reading
Steps for Replacing Ignition Switch 760/960
Steps for replacing Ignition switch in 760/960 Vehicle… It’s quite easy to replace the switch in a 760 and 960 vehicle, it can get a little trickier in the 740/940 series because the ignition is dash-mounted. For the 760/960: 1) … Continue reading
Leave a comment
V70GLT 2000 Starting issue – Cold or Hot
This is a classic problem caused by a faulty ignition switch. “This uncovered something I hadn’t noticed before…that the fuel pump does not come on right away when the key is in the ‘ON’ position. Sometimes I have to wait … Continue reading
Leave a comment
