Tag Archives: intake manifold
Cylinder Head Replacement
Cylinder Head Replacement Project – With Photos Timeline: I completed the teardown in about 10 hours. Shipped out the head to Cylinder-Heads.com in Clearwater for rebuild and I just got it back today. In the meantime, I disassembled the intake … Continue reading
Improve Air Delivery to N/A Engines w/ VVIS Mod
The 20V non turbo Volvo 850 models had a variable inlet manifold, to increase engine efficiency. Well this topic is all about the control of this manifold and improve the behavior of the engine. OK you will reach not more … Continue reading
Due for PCV Job
Tips on doing the PVC on your 850, S70 or V70 “I have not removed the injectors on any of them. The only thing that is tricky is getting the fuel return line off since the hose is a little … Continue reading
How to Fix Clogged PCV
The only parts you have to buy is the oil trap, there are two versions. The one you need depends on your engine serial # and FCP will ask for that… Continue reading
Register
Search
Help
