Tag Archives: Radiator Cap
Update your Radiator Cap! 200/700/900 Series Volvos
Radiator Caps: Grey vs Green Check under the bonnet – if you have a gray cap on the coolant reservoir, and you have to occasionally add water to maintain coolant levels (in other words, a small leak has developed), please … Continue reading
Radiator Cap – Cars that DON’T Take the Later Cap
Use the Correct Radiator Cap! This post is to be read in conjunction with Update your Radiator Cap! 2/7/9/series. The following models, year and engine designation DO NOT take the later cap which is rated at 1.5bar. Using the later … Continue reading
Register
Search
Help
