Tag Archives: replace thermostat
Replacement Thermostat… Which Brand to Buy?
Vernat, Wahler, SuperStat, OEM… which choice should you make for your replacement thermostat? Thermostat Brands
Replace Thermostat Volvo 850, S70, V70, C70 or XC70
Overview The thermostat is located between the engine and the radiator. The thermostat acts as a valve that stays closed during engine warm-up. When the thermostat is closed, it prevents coolant from leaving the engine and circulating through the radiator. … Continue reading
Register
Search
Help
