Volvo Repair Database
Tag Archives: spark plug
XC90 DIY: Oil, Spark Plugs, Air & Fuel Filters, Transmission Fluid Flush
Spark Plugs 1 – The turbo line that goes front to back will need to be removed. What I did was just remove the clamp ring towards the front of the line (because it is easiest to get to), but there is also one at the back. If you can do what I did, loosen the front clamp and pull the plastic hose out of the rubber. Continue reading
