Tag Archives: spring seats
Suspension Rattle S70 T5
Diagnosing Worn Spring Seats For about a week now, I have noticed what I can only attempt to describe as a quiet ‘clunking/rattling‘ noise from my front left suspension when I go over slight bumps in the road. Sorry I … Continue reading
S70 T5 – Needs New Suspension?
Suspension overhaul shopping list and Tutorial 2 inner tie rods, 2 outer tie rods, 2 spring seats. You also might want to get two strut mounts, but they’re about $100 apiece. You probably also need new sway bar end links. … Continue reading
Knock knock, from the top of the struts
Q “I’ve recently changed all the ball joint connections with the exception of the inner tie rods. At 80,000 miles and in frigid weather, the top of the struts knock at every bump in the road. The shocks are acceptable … Continue reading
Register
Search
Help
