Volvo Repair Database
Tag Archives: starter motor
1996 850 non-turbo Starter Replacement Tutorial
I posted my 1996 850 starter replacement tutorial as an addendum to Tina’s outstanding 1998 S70 starter replacementtopic. Plan on 3 hours, if you’re an average DIY mechanic like I am. You don’t need exotic tools, just 10mm-14mm ratchet, and … Continue reading
Leave a comment
How to Change Starter Motor S40 & V40?
To remove: Disconnect battery negative lead. Disconnect positive lead and connector of starter relay. Remove three fixing bolts from starter motor. Top bolt also holds the cable support. Slide starter motor to rear, turn and lift upwards. To reinstall: Transfer … Continue reading
Leave a comment
Tutorial – Replacing the Starter Motor 1998 S70
Step-by-Step 1998 S70 starter motor replacement with pictures I just accomplished this job, here’s how I did it. Please forgive my lack of knowledge of the correct names for many parts, I am a complete amateur and I stumbled my … Continue reading
