Volvo Repair Database
Tag Archives: Timing Marks
Cam Adjustment Documentation & Advice
The MVS Directory of Cam Adjustment This is the repository of everything we at MVS Forums know about setting, advancing and retarding timing on Volvo inline-5 engines for performance, and for standard factory settings after a timing belt change. This … Continue reading
Timing Mark Alignment and Adjustment
I obsessed over it too and in the end, and after taking an entire day setting and resetting, I just went with it. I couldn’t get it spot on. Some folks can. If you rotated and nothing hangs up you … Continue reading
S80 Timing Belt Questions
1. Make sure your timing marks all line up before removing the belt! 2. After installing the new belt, rotate your engine two full turns by hand (turn the 30mm nut with a wrench; socket extensions help here) and verify … Continue reading
1997 Volvo S90 Timing Marks
1997 S90 with DOHC Timing Mark I am doing valve repairs after a broke timing belt. while I have the head off I can see that the timing mark on the crank does not have the number one piston at … Continue reading
Leave a comment
