Volvo Repair Database
Tag Archives: Transmission Fluid
Volvo Engine Oil Change — The Easy Way
I wrote a short and sweet DIY for Oil Change using wood ramps and no need to jack the car up. Basically as sweet and simple as possible! You can do this for under 30 minutes. [Have a newer Volvo? … Continue reading
Leave a comment
Volvo 240 Diagnose & Repair: TPS, MAF, PCV, Acceleration, Fluids
This Volvo Forum topic covers a whole slew of 240 issues. It’s “all over the map”, but you’ll find something to interest most 240 owners in it. mass airflow sensor (MAF): how to check it throttle position sensor (TPS): how … Continue reading
Change 740/760 Transmission Fluid? How Much?
Change 740/760 Transmission Fluid? How Much? When I bought the car, it had ~112,000 miles, now it has about 116,000. I am unsure of what transmission maintenance was performed (if any other than adding fluid) before the car came into … Continue reading
Leave a comment
S80 1G 6Cyl Auto Transmission Fluid & Filter Change How-To
This is for the first generation S80 cars that use the GM 4T65E automatic transmission. Volvo says that the fluid in these transmissions is “lifetime.” What does that mean? I think it means just long enough to get out of … Continue reading
Leave a comment
1999+ Transmission Fluid Caveat
[no comments] Continue reading
Leave a comment
