Tag Archives: Transmission Fluid Drain & Fill
How Often Should You Flush Your Transmission Fluid?
I have been flushing my ATF (as opposed to a Transmission Drain & Fill… in other words: where I disconnect the cooler hose and flush ATF) using the following guidelines: Mobil Synthetic ATF (It take about 9-10 qts for a … Continue reading
2001 V70 2.4T ATF Drain and Fill Tutorial
Save Money – Get the Toyota Transmission Fluid I did all the research I could do on the topic and made the decision to go with the Toyota Type IV ATF going with the simplified drain and fill method. We … Continue reading
What Is “Stage 0″?
Stage 0 Overview Stage 0 means to get your car up to the condition it was when it was new. It makes sense in every situation. Are you a regular driver? You’ll improve fuel economy and dependability. Modder/performance/horsepower guy? You’ll … Continue reading
Register
Search
Help
