Volvo Repair Database
Tag Archives: V70 AWD
How to Replace Oil Return Line on AWD Volvos
After about 4-5 hours under car I have the turbo oil return line disconnected at the turbo; old gasket (falling apart) removed. Problem: Dealer sold me an orange O ring with the turbo oil return line gasket. Said it went … Continue reading
How to Maintain Your AWD Volvo’s Driveshaft
For all AWD Volvo Models MVS Forum member Jimmy tells us explicitly how to make your AWD Volvo system go well over 100k miles. If you’re reading this with 150k+ miles on yours, and you haven’t “done anything” to extend … Continue reading
Leave a comment
How to change rear bevel fluid on AWD P2 Volvos
Tutorial – Change Bevel/Angle Fluid on AWD 2003+ Volvos Before proceeding with this tutorial, ensure that your Volvo AWD system is the same one as is on my 2004 V70 R. If it is, you’ll have no problem. If not, … Continue reading
Leave a comment
How to change Haldex fluid on AWD P2 Volvos
Volvo Haldex Fluid Change Tutorial This is something most people can do… the hardest part is getting the old fluid out (no drain plug). Angle gear fluid change tutorial coming soon. How to change angle gear and Haldex fluid on … Continue reading
Leave a comment
Dual exhaust for 98 V70 AWD
For those with V70 AWD versions with the stock single outlet muffler on the right side, the 2000 V70 R dual muffler is a direct fit. I had one installed today on my 98 AWD. There are lots of earlier … Continue reading
