Tag Archives: Vacuum Line
Turbo Control Valve and its Correct Hosing Routing
TCV Vacuum Hose Routing De-Confusement I have searched for TCV diagram for my 95 Volvo 850 T5 but getting confused with these 2 diagrams. When i look at both of my cars the wastegate actuator has been marked yellow and … Continue reading
1998 V70R Turbo vacuum line – How to get it off?
How to Replace Vacuum Hoses that go to Turbo “As far as getting that red coded vac line to the turbo off, the one below the compression bypass valve, I sprayed a lot of WD-40 on that fitting from below. … Continue reading
Vacuum line clamps
Vacuum hose clamps – is the Type Important? Screw clamps, pinch clamps, or some other? Or do I need them at all? Will the hose just stay on? Vacuum line clamps
Vacuum Line Routing for Air Box Thermostat
Air Box Thermostat. Misha gives us some great pictures of the vacuum line routing for the vacuum line controlled air box thermostat. 1997 850 Help locating vacuum hose
Register
Search
Help
