Tag Archives: Volvo 5-cylinder
Troubleshoot A Dead Volvo 5-cyl Engine
Tips on Finding the Problem on White Engines Pull the head and inspect before doing any other plotting and planning. If the problem were to be rusty or stuck valves then the fix is easy. The cam sensor is different … Continue reading
Step-by-step Tutorial Replacing Head Gasket: Volvo 5-cyl
This is a link to an outstanding step-by-step tutorial on replacing the head gasket on a Volvo 5-cylinder engine. This is one of the best tutorials on anything Volvo that I’ve seen anywhere. I was frustrated that there wasn’t “more” … Continue reading
850 engine replacement woes (& Updates)
A Seven Month Volvo 850 Engine Replacement Saga Tears, blood, sweat and oil: Lee’s tale of sadness and triumph in the face of mechanical adversity. 850 engine replacement woes (& Updates)
1995 Volvo 850 Engine & Transmission Removal
Astoundingly well-documented, excellent write up on engine removal. One-hundred and sixty photographs detail this procedure, with captions for nearly every one. You can use this for almost any inline 5-cylinder Volvo. 1995 Volvo 850 Auto Engine and transmission Removal
Register
Search
Help
