Timing Mark Alignment and Adjustment
I obsessed over it too and in the end, and after taking an entire day setting and resetting, I just went with it. I couldn’t get it spot on. Some folks can. If you rotated and nothing hangs up you are good to go. Put the key in and start it up.
Timing Mark alignment and adjustment
Forum views 13952Forum replies 39
Date April 8, 2011
5 responses to “Timing Mark Alignment and Adjustment”
  1. john says:
    how do you replace the front oil seal on the camshaft on a 91 volvo 940gl non-turbo?
  2. Regan F. Scheepers says:
    Hi, I was hoping that some-one could please help me with the timing of my Volvo S60 2.4 turbo (2003)I have replaced my timing belt the past weekend and although the car seems to be performing as usual, the engine warning light have come on. I am under the impresssion that I have not lined up the marks as I should have. I don’t have any specialised tooling. So I will appreciate it if somebody could please give me some guidelines on what is the correct way to set the timing. If at all possible please send me some pictures that shows the marks on the cam pulleys as well as the crank pulley. Also give me some advise as to how I can fix the cam pulleys without having to buy tools ( the budget in completely depleted.
    Thanks in advance.
    Regan
  3. mel says:
    2000 s80 t6 whats the correct crankshaft mark for tdc when replacing head after replacing due to bent valves after timing belt idler failure.
  4. greg says:
    someone has cut part of my timing cover off, doing so they cut off the timing marks. the tension pulley failed and i need to set the cam timing with the belt off. any ideas?
  5. Fred Triana says:
    Hi having problems as to were to poi t the timeing light on the volvo c202 1978 on shaft help its runs but in higber speed it stats to mis help
