Following up on Towing a Trailer with an 850 and Towing a Trailer with an 850 part II blog post, I’d like to add that I had my total weight calculated at a truck weigh station, and it was well over what Volvo recommends for the towing limit. I’m embarrassed to relate this, being a somewhat careful Volvo owner, but it’s a good “heads up” for all you trailer novices out there that are thinking of doing this.
The trailer can and will fill up quickly, and without experience at estimating furniture weight, you’ll go over recommended weight limits quickly and without knowing it.
When you’re renting a trailer, look it over before accepting it. The lot guy tried to give me a trailer with retreaded tires that had big chunks missing from the tread. No thanks. I asked for another one.
I paid around $275 (turned out to be less than the shop said) for my hitch, installation included, and it was done by pros. I don’t know if this is a good or bad price, but having it done by a shop that does these every day took one variable out of the equation. That was well worth the $275. The wiring worked without fuss, and the hitch proved itself after the 1300-mile haul.
Also, I’d like to note that I did a complete tuneup “Stage 0” before my trip, including new tires.
Register
Search
Help
Many thanks for the update, Matthew. A quick question, for those of us thinking of doing something similar: did you experience any tranny/overheating issues (esp. when going uphill through the rockies)?
Best,
Raul
No, no tranny or overheating issues at all. Temp gauge stayed at 3 o’clock like it’s pinned there (as it’s done in every driving condition since I’ve owned the car [2000]).
Just curious- how much over the recommended weight limit did you go? Btw, glad you got moved ok and without incident!
MIJ
The total weight (car+trailer) was 8200 pounds if I recall correctly. I remember thinking “Holy smokes. This is bad, but I’m in Idaho. I have no good choices except keep traveling to Denver.”
Car = 3300 (unloaded)
Trailer = 900 (unloaded)
Stuff, therefore = 4000
Did you do anything to the suspension, etc either before or after the tow? Also, how level did it ride?
Jay, I did nothing to the suspension. It rode a bit nose-up.
