Change S80 Trans Fluid Or Not?
I have a 2000 S80 T6 with 126K on it and I’m sure the fluid has never been changed. The color of the fluid is a light brown, about the color of new motor oil. Is this the color it is suppose to be and should I worry about changing it?
Register
Search
Help
The color of ATF is supposed to be bright red. If its brown you could have a bad transmission very soon. Change it ASAP!
