Volvo Repair Database
Replacing an 850 Transmission
Here is phoenix_iii’s saga and resolution when he transferred a AW/50-42 transmission into his ’95 850 Turbo from a ’96. Although the transmissions were the same number he ran into a different wiring, especially the speed sensor. If you’re having to replace a transmission in your 850, this thread could be valuable. Thanks, phoenix_iii for hanging in there and finally figuring out all the kinks!
  1. Dealing with Speed Sensor Connectors
  2. Transmission Filter Replacement
  3. What To Replace When Replacing Shocks
  4. Transmission Fluid Flush Tip 4
  5. ’93-’95 Transmission Trouble Codes
This entry was posted in Transmission, Driveshaft, Bevel Gear, Volvo 850. Bookmark the permalink.
