Turn signal, hazard lights fix
A component level fix for the failure prone hazard / turn signal relay in the early S/V series cars.  Fix the switch yourself for under $2.00.
You need to remove the hazard push button from the unit, gently pry behing this button on the short side, you will see what I mean, you need to pry on both short sides to undo the catch that it has.
Than the next step is to remove the housing, again prying gently, the housing is made of quite thin plastic, and slide this off the unit.
Surprise, IC etc. etc. fansy stuff. But you will see three capacitors, two small ones and one larger one.
Forum views 6281Forum replies 6
Date March 3, 2010
One response to “Turn signal, hazard lights fix”
  1. Paul says:
    Thanks – this was very helpful. I pulled out the hazard switch on my 1999 V70 and disconnected the harness. Couldn’t see anything that I could do to fix it so I just reattached the switch and … voila. Turn signals and hazards are on again.
