Codes: 1999+ Volvos
About Volvo Trouble Codes (DTC)
OBD II is a diagnostics system designed to meet statutory requirements. A standardized instrument for fault-tracing can be plugged in to the data link connector (DLC) (OBD II socket) to read diagnostic trouble codes (DTCs) and system parameters.
Looking for 1996 to 1998 Volvo Trouble Code Help?
Or codes on 1992-1995 Volvos?
OBD II contains only emissions related diagnostic trouble codes (DTCs) and parameters. It cannot provide the comprehensive range of information available from the Volvo On-board diagnostics system. Volvo has its own diagnostic trouble code (DTC) designations that adhere to the in-house Volvo On-board Diagnostics protocol (called DII from model year 1999).
Table explanations
The table below is a conversion table between standardised diagnostic trouble codes (DTCs) (SAE/ISO) and the equivalent Volvo diagnostic trouble codes (DTCs) (DII). SAE/ISO diagnostic trouble code (DTC): Standardized diagnostic trouble code (DTC) according to SAE J2012/ISO 15031-6. The diagnostic trouble code (DTC) can be read off on vehicles with standardised on-board diagnostic systems for emissions related faults, certified in accordance with OBD II.
Please help us add to this by posting your additions to this topic.
Volvo Codes Table 1999+
SAE/ISO Volvo DII DTC designation Fault type
P0010 ECM‑6400 Intake camshaft reset valve Signal too low or signal missing
P0011 ECM‑640A Camshaft control, intake Faulty signal
P0013 ECM‑6410 Exhaust camshaft reset valve Signal too low or signal missing
P0014 ECM‑641A Camshaft control, exhaust Faulty signal
P0016 ECM‑643A Camshaft position, intake Signal too low
P0016 ECM‑643A Camshaft position, intake Signal too high
P0017 ECM‑644A Camshaft position, exhaust Signal too low
P0017 ECM‑644A Camshaft position, exhaust Signal too high
P0030 ECM‑2810 Front heated oxygen sensor (HO2S), preheating Signal missing. Intermittent fault
P0030 ECM‑2810 Front heated oxygen sensor (HO2S), preheating Signal missing. Permanent fault
P0031 ECM‑2810 Front heated oxygen sensor (HO2S), preheating Signal too low. Intermittent fault
P0031 ECM‑2810 Front heated oxygen sensor (HO2S), preheating Signal too low. Permanent fault
P0032 ECM‑2810 Front heated oxygen sensor (HO2S), Signal too high. preheating Intermittent fault
P0032 ECM‑2810 Front heated oxygen sensor (HO2S), preheating Signal too high. Permanent fault
P0036 ECM‑2A20 Heated oxygen sensor (HO2S) bank Signal missing 1, preheating
P0037 ECM‑2A20 Heated oxygen sensor (HO2S) bank Signal too low 1, preheating
P0038 ECM‑2A20 Heated oxygen sensor (HO2S) bank Signal too high 1, preheating
P0040 ECM‑280C Front heated oxygen sensors (HO2S) Faulty signal
P0050 ECM‑2910 Front heated oxygen sensor (HO2S) Signal missing preheating, bank 2
P0051 ECM‑2910 Front heated oxygen sensor (HO2S) Signal too low preheating, bank 2
P0052 ECM‑2910 Front heated oxygen sensor (HO2S) Signal too high preheating, bank 2
P0056 ECM‑2B20 Heated oxygen sensor (HO2S) bank Signal missing 2, preheating
P0057 ECM‑2B20 Heated oxygen sensor (HO2S) bank Signal too low 2, preheating
P0058 ECM‑2B20 Heated oxygen sensor (HO2S) bank Signal too high 2, preheating
P0071 ECM‑1100 Outer temperature sensor Faulty signal
P0072 ECM‑1100 Outer temperature sensor Signal too low
P0073 ECM‑1100 Outer temperature sensor Signal too high
P0101 ECM‑130A Intake air leakage Faulty signal
P0102 ECM‑1300 Mass air flow (MAF) sensor Flow too low. Intermittent fault
P0102 ECM‑1300 Mass air flow (MAF) sensor Flow too low. Permanent fault
P0103 ECM‑1300 Mass air flow (MAF) sensor Flow too high. Intermittent fault
P0103 ECM‑1300 Mass air flow (MAF) sensor Flow too high. Permanent fault
P0105 ECM‑1000 Control module Faulty signal
P0107 ECM‑1000 Control module Signal too high / signal too low. Intermittent fault
P0107 ECM‑1000 Control module Signal too high / signal too low. Permanent fault
P0108 ECM‑1000 Control module Signal too high / signal too low. Intermittent fault
P0108 ECM‑1000 Control module Signal too high / signal too low. Permanent fault
P0111 ECM‑1200 Intake air temperature (IAT) inlet Faulty signal
P0112 ECM‑1200 Intake air temperature (IAT) inlet Signal too high. Intermittent fault
P0112 ECM‑1200 Intake air temperature (IAT) inlet Signal too high. Permanent fault
P0113 ECM‑1200 Intake air temperature (IAT) inlet Signal too low. Intermittent fault
P0113 ECM‑1200 Intake air temperature (IAT) inlet Signal too low. Permanent fault
P0121 ECM‑9150 Throttle unit, potentiometer 1 Faulty signal
P0122 ECM‑9150 Throttle unit, potentiometer 1 Signal too low
P0123 ECM‑9150 Throttle unit, potentiometer 1 Signal too high
P0128 ECM‑201A Thermostat Faulty signal
P0130 ECM‑280A Front heated oxygen sensor (HO2S), faulty signal Signal missing. Intermittent fault
P0130 ECM‑280A Front heated oxygen sensor (HO2S), faulty signal Signal missing. Permanent fault
P0132 ECM‑280A Front heated oxygen sensor (HO2S), Signal too high. faulty signal Intermittent fault
P0132 ECM‑280A Front heated oxygen sensor (HO2S), faulty signal Signal too high. Permanent fault
P0133 ECM‑280A Front heated oxygen sensor (HO2S), faulty signal Signal too low. Intermittent fault
P0133 ECM‑280A Front heated oxygen sensor (HO2S), faulty signal Signal too low. Permanent fault
P0134 ECM‑280A Front heated oxygen sensor (HO2S) Faulty signal. Intermittent fault
P0134 ECM‑280A Front heated oxygen sensor (HO2S) Faulty signal. Permanent fault
P0135 ECM‑290A Front heated oxygen sensor (HO2S), preheating Faulty signal. Intermittent fault
P0135 ECM‑290A Front heated oxygen sensor (HO2S), preheating Faulty signal. Permanent fault
P0136 ECM‑2A0A Rear heated oxygen sensor (HO2S) Signal missing. Intermittent fault
P0136 ECM‑2A0A Rear heated oxygen sensor (HO2S) Signal missing. Permanent fault
P0137 ECM‑2A0A Rear heated oxygen sensor (HO2S)
P0138 ECM‑2A0A Rear heated oxygen sensor (HO2S) Signal too high. Intermittent fault
P0138 ECM‑2A0A Rear heated oxygen sensor (HO2S) Signal too high. Permanent fault
P0140 ECM‑2A1A Rear heated oxygen sensor (HO2S) Signal too low aging
P0140 ECM‑2A1A Rear heated oxygen sensor (HO2S) Signal too high aging
P0140 ECM‑2A1A Rear heated oxygen sensor (HO2S) Signal missing aging
P0141 ECM‑2A2A Rear heated oxygen sensor (HO2S) Faulty signal preheating
P0150 ECM‑290A Front heated oxygen sensor (HO2S), bank 2 Signal missing. Intermittent fault
P0150 ECM‑290A Front heated oxygen sensor (HO2S), bank 2 Signal missing. Permanent fault
P0152 ECM‑290A Front heated oxygen sensor (HO2S), Signal too high bank 2
P0153 ECM‑290A Front heated oxygen sensor (HO2S), bank 2 Signal too low. Intermittent fault
P0153 ECM‑290A Front heated oxygen sensor (HO2S), bank 2 Signal too low. Permanent fault
P0154 ECM‑290A Front heated oxygen sensor (HO2S), bank 2 Faulty signal. Intermittent fault
P0154 ECM‑290A Front heated oxygen sensor (HO2S), bank 2 Faulty signal. Permanent fault
P0155 ECM‑2910 Front heated oxygen sensor (HO2S) Faulty signal. Intermittent preheating, bank 2 fault
P0155 ECM‑2910 Front heated oxygen sensor (HO2S) Faulty signal. Permanent preheating, bank 2
P0156 ECM‑2B0A Rear heated oxygen sensor (HO2S) Signal missing. Intermittent bank 2
P0156 ECM‑2B0A Rear heated oxygen sensor (HO2S) Signal missing. Permanent bank 2
P0157 ECM‑2B0A Rear heated oxygen sensor (HO2S), bank 2 fault
P0158 ECM‑2B0A Rear heated oxygen sensor (HO2S) Signal too high. bank 2 Intermittent fault
P0158 ECM‑2B0A Rear heated oxygen sensor (HO2S) Signal too high. Permanent bank 2 fault
P0160 ECM‑2B1A Rear heated oxygen sensor (HO2S) Signal too low ageing, bank 2
P0160 ECM‑2B1A Rear heated oxygen sensor (HO2S) Signal too high ageing, bank 2
P0160 ECM‑2B1A Rear heated oxygen sensor (HO2S) Signal missing ageing, bank 2
P0161 ECM‑2B2A Rear heated oxygen sensor (HO2S) Faulty signal preheating, bank 2
P1729 ECM‑9170 Throttle unit Faulty signal
P0201 ECM‑2310 Injector 1 Signal missing. Intermittent fault
P0201 ECM‑2310 Injector 1 Signal missing. Permanent fault
P0202 ECM‑2320 Injector 2 Signal missing. Intermittent fault
P0202 ECM‑2320 Injector 2 Signal missing. Permanent fault
P0203 ECM‑2330 Injector 3 Signal missing. Intermittent fault
P0203 ECM‑2330 Injector 3 Signal missing. Permanent fault
P0204 ECM‑2340 Injector 4 Signal missing. Intermittent fault
P0204 ECM‑2340 Injector 4 Signal missing. fault
P0205 ECM‑2350 Injector 5 Signal missing. Intermittent fault
P0205 ECM‑2350 Injector 5 Signal missing. Permanent fault
P0206 ECM‑2360 Injector 6 Signal missing. Intermittent fault
P0206 ECM‑2360 Injector 6 Signal missing. Permanent fault
P0221 ECM‑9160 Throttle unit, potentiometer 2 Faulty signal
P0222 ECM‑9160 Throttle unit, potentiometer 2 Signal too low
P0223 ECM‑9160 Throttle unit, potentiometer 2 Signal too high
P0230 ECM‑2400 Fuel pump (FP) relay Signal missing. Intermittent fault
P0230 ECM‑2400 Fuel pump (FP) relay Signal missing. Permanent fault
P0231 ECM‑2400 Fuel pump (FP) relay Signal too low. Intermittent fault
P0231 ECM‑2400 Fuel pump (FP) relay Signal too low. Permanent fault
P0232 ECM‑2400 Fuel pump (FP) relay Signal too high. Intermittent fault
P0232 ECM‑2400 Fuel pump (FP) relay Signal too high. Permanent fault
P0234 ECM‑6805 Turbocharger (TC) control valve Pressure too high boost pressure fault
P0235 ECM‑1600 Boost pressure sensor Faulty signal
P0236 ECM‑170F Atmospheric pressure sensor / Faulty signal boost pressure sensor range check
P0237 ECM‑1600 Boost pressure sensor Signal too low
P0238 ECM‑1600 Boost pressure sensor Signal too high
P0243 ECM‑6800 Turbocharger (TC) control valve Signal missing. Intermittent fault
P0243 ECM‑6800 Turbocharger (TC) control valve Signal missing. Permanent fault
P0245 ECM‑6800 Turbocharger (TC) control valve Signal too low. Intermittent fault
P0245 ECM‑6800 Turbocharger (TC) control valve Signal too low. Permanent fault
P0246 ECM‑6800 Turbocharger (TC) control valve Signal too high. Intermittent fault
P0246 ECM‑6800 Turbocharger (TC) control valve Signal too high. Permanent fault
P0261 ECM‑2310 Injector 1 Signal too low. Intermittent fault
P0261 ECM‑2310 Injector 1 Signal too low. Permanent fault
P0262 ECM‑2310 Injector 1 Signal too high. Intermittent fault
P0262 ECM‑2310 Injector 1 Signal too high. Permanent fault
P0264 ECM‑2320 Injector 2 Signal too low. Intermittent fault
P0264 ECM‑2320 Injector 2 Signal too low. Permanent fault
P0265 ECM‑2320 Injector 2 Signal too high. Intermittent fault
P0265 ECM‑2320 Injector 2 Signal too high. Permanent fault
P0267 ECM‑2330 Injector 3 Signal too low. Intermittent fault
P0267 ECM‑2330 Injector 3 Signal too low. Permanent fault
P0268 ECM‑2330 Injector 3 Signal too high. Intermittent fault
P0268 ECM‑2330 Injector 3 Signal too high. Permanent fault
P0270 ECM‑2340 Injector 4 Signal too low. Intermittent fault
P0270 ECM‑2340 Injector 4 Signal too low. Permanent fault
P0271 ECM‑2340 Injector 4 Signal too high. Intermittent fault
P0271 ECM‑2340 Injector 4 Signal too high. Permanent fault
P0273 ECM‑2350 Injector 5 Signal too low. Intermittent fault
P0273 ECM‑2350 Injector 5 Signal too low. Permanent fault
P0274 ECM‑2350 Injector 5 Signal too high. Intermittent fault
P0274 ECM‑2350 Injector 5 Signal too high. Permanent fault
P0276 ECM‑2360 Injector 6 Signal too low. Intermittent fault
P0276 ECM‑2360 Injector 6 Signal too low. Permanent fault
P0277 ECM‑2360 Injector 6 Signal too high. Intermittent fault
P0277 ECM‑2360 Injector 6 Signal too high. Permanent fault
P0299 ECM‑6806 Turbocharger (TC) control valve Pressure too low flow fault
P0300 ECM‑3503 Misfire, at least one cylinder Emissions impact / catalytic converter damage
P0301 ECM‑3513 Misfire cylinder 1 Emissions impact / catalytic converter damage
P0302 ECM‑3523 Misfire cylinder 2 Emissions impact / catalytic converter damage
P0303 ECM‑3533 Misfire cylinder 3 Emissions impact / catalytic converter damage
P0304 ECM‑3543 Misfire cylinder 4 Emissions impact / catalytic converter damage
P0305 ECM‑3553 Misfire cylinder 5 Emissions impact / catalytic converter damage
P0306 ECM‑3563 Misfire cylinder 6 Emissions impact / catalytic converter damage
P0324 ECM‑3400 Knock sensor (KS), test pulse Signal too high / signal too low. Intermittent fault
P0324 ECM‑3400 Knock sensor (KS), test pulse Signal too high / signal too low. Permanent fault
P0324 ECM‑34E0 Knock sensor (KS), offset Signal too high / signal too low. Intermittent fault
P0324 ECM‑34E0 Knock sensor (KS), offset Signal too high / signal too low. Permanent fault
P0324 ECM‑34F0 Knock sensor (KS), test pulse Signal too high / signal too low. Intermittent fault
P0324 ECM‑34F0 Knock sensor (KS), test pulse Signal too high / signal too low. Permanent fault
P0327 ECM‑3410 Knock sensor (KS), front Signal too low. Intermittent fault
P0327 ECM‑3410 Knock sensor (KS), front Signal too low. Permanent fault
P0328 ECM‑3410 Knock sensor (KS), front Signal too high. Intermittent fault
P0328 ECM‑3410 Knock sensor (KS), front Signal too high. Permanent fault
P0332 ECM‑3420 Knock sensor (KS), rear Signal too low. Intermittent fault
P0332 ECM‑3420 Knock sensor (KS), rear Signal too low. Permanent fault
P0333 ECM‑3420 Knock sensor (KS), rear Signal too high. Intermittent fault
P0333 ECM‑3420 Knock sensor (KS), rear Signal too high. Permanent fault
P0335 ECM‑5200 Engine speed (RPM) sensor Signal missing
P0336 ECM‑5200 Engine speed (RPM) sensor Faulty signal
P0337 ECM‑5200 Engine speed (RPM) sensor Signal too low
P0338 ECM‑5200 Engine speed (RPM) sensor Signal too high
P0340 ECM‑3000 Camshaft position (CMP) sensor, intake Faulty signal or signal missing
P0342 ECM‑3000 Camshaft position (CMP) sensor Signal too low. Intermittent intake fault
P0342 ECM‑3000 Camshaft position (CMP) sensor Signal too low. Permanent intake fault
P0343 ECM‑3000 Camshaft position (CMP) sensor Signal too high. intake Intermittent fault
P0343 ECM‑3000 Camshaft position (CMP) sensor Signal too high. Permanent intake fault
P0344 ECM‑3000 Camshaft position (CMP) sensor Faulty signal or signal intake missing
P0345 ECM‑3010 Camshaft position (CMP) sensor Faulty signal or signal exhaust missing
P0347 ECM‑3010 Camshaft position (CMP) sensor Signal too low exhaust
P0348 ECM‑3010 Camshaft position (CMP) sensor Signal too high exhaust
P0349 ECM‑3010 Camshaft position (CMP) sensor Faulty signal or signal exhaust missing
P0351 ECM‑3300 Ignition coil cylinder 1, signal Signal missing. Intermittent fault
P0351 ECM‑3300 Ignition coil cylinder 1, signal Signal missing. Permanent fault
P0352 ECM‑3310 Ignition coil cylinder 2, signal Signal missing. Intermittent fault
P0352 ECM‑3310 Ignition coil cylinder 2, signal Signal missing. Permanent fault
P0353 ECM‑3320 Ignition coil cylinder 3, signal Signal missing. Intermittent fault
P0353 ECM‑3320 Ignition coil cylinder 3, signal Signal missing. Permanent fault
P0354 ECM‑3330 Ignition coil cylinder 4, signal Signal missing. Intermittent fault
P0354 ECM‑3330 Ignition coil cylinder 4, signal Signal missing. Permanent fault
P0355 ECM‑3340 Ignition coil cylinder 5, signal Signal missing. Intermittent fault
P0355 ECM‑3340 Ignition coil cylinder 5, signal Signal missing. Permanent fault
P0420 ECM‑4801 Three‑way catalytic converter (TWC) Intermittent fault efficiency, bank 1
P0420 ECM‑4801 Three‑way catalytic converter (TWC) Permanent fault efficiency, bank 1
P0430 ECM‑4901 Three‑way catalytic converter (TWC) Intermittent fault efficiency, bank 2
P0430 ECM‑4901 Three‑way catalytic converter (TWC) Permanent fault efficiency, bank 2
P0443 ECM‑4000 Evaporative emission system (EVAP) Signal missing. Intermittent valve fault
P0443 ECM‑4000 Evaporative emission system (EVAP) Signal missing. Permanent valve fault
P0444 ECM‑4000 Evaporative emission system (EVAP) Signal too high. valve Intermittent fault
P0444 ECM‑4000 Evaporative emission system (EVAP) Signal too high. Permanent valve fault
P0445 ECM‑4000 Evaporative emission system (EVAP) Signal too low. Intermittent valve fault
P0445 ECM‑4000 Evaporative emission system (EVAP) Signal too low. Permanent valve fault
P0446 ECM‑4010 Leak diagnostic unit, valve Signal too high
P0447 ECM‑4010 Leak diagnostic unit, valve Signal missing
P0448 ECM‑4010 Leak diagnostic unit, valve Signal too low
P0455 ECM‑400C Fuel tank system, leakage
P0456 ECM‑400C Fuel tank system, leakage
P0457 ECM‑4338 Fuel tank filler cap missing
P0460 ECM‑405C Fuel level sensor
P0461 ECM‑4050 Fuel level sensor Faulty signal
P0462 ECM‑4050 Fuel level sensor Signal too low
P0463 ECM‑4050 Fuel level sensor Signal too high
P0464 ECM‑4050 Fuel level sensor Signal missing
P0480 ECM‑6110 Engine cooling fan (FC) relay Signal missing. Intermittent fault
P0480 ECM‑6110 Engine cooling fan (FC) relay Signal missing. Permanent fault
P0483 ECM‑6100 Engine cooling fan (FC) control Faulty signal module
P0484 ECM‑6100 Engine cooling fan (FC) control Faulty signal module
P0485 ECM‑6100 Engine cooling fan (FC) control Faulty signal module
P0496 ECM‑4007 Evaporative emission system (EVAP) Signal too high
P0497 ECM‑4007 Evaporative emission system (EVAP) Signal too low
P0500 ECM‑510F Speed signal
P0506 ECM‑990A Idle air control (IAC) Faulty signal
P0507 ECM‑990A Idle air control (IAC) Faulty signal
P0530 ECM‑5000 A/C pressure sensor Signal missing. Intermittent fault
P0530 ECM‑5000 A/C pressure sensor Signal missing. Permanent fault
P0532 ECM‑5000 A/C pressure sensor Signal too low. Intermittent fault
P0532 ECM‑5000 A/C pressure sensor Signal too low. Permanent fault
P0533 ECM‑5000 A/C pressure sensor Signal too high. Intermittent fault
P0533 ECM‑5000 A/C pressure sensor Signal too high. Permanent fault
P0560 ECM‑8010 Battery voltage Faulty signal
P0562 ECM‑8010 Battery voltage Signal too low
P0563 ECM‑8010 Battery voltage Signal too high
P0564 ECM‑928C Control module, communication fault Faulty signal
P0571 ECM‑9400 Brake pedal sensor Signal missing
P0573 ECM‑9400 Brake pedal sensor Signal too high
P0579 ECM‑928C Control module, communication Faulty signal fault
P0580 ECM‑928C Control module, communication Faulty signal fault
P0581 ECM‑928C Control module, communication Faulty signal fault
P0602 ECM‑531D Control module, internal fault
P0604 ECM‑9050 RAM memory fault Internal fault. Intermittent fault
P0604 ECM‑9050 RAM memory fault Internal fault. Permanent fault
P0605 ECM‑9060 ROM memory fault Internal fault. Intermittent fault
P0605 ECM‑9060 ROM memory fault Internal fault. Permanent fault
P0606 ECM‑9070 Control module, internal fault Intermittent fault
P0606 ECM‑9070 Control module, internal fault Permanent fault
P0607 ECM‑711A Engine control module (ECM), internal fault Signal too high / signal too low. Intermittent fault
P0607 ECM‑711A Engine control module (ECM), internal fault Signal too high / signal too low. Permanent fault
P0630 ECM‑720A Immobilizer communication Faulty signal. Intermittent fault
P0630 ECM‑720A Immobilizer communication Faulty signal. Permanent fault
P0638 ECM‑91A7 Throttle unit Faulty signal
P0634 ECM‑716D Engine control module (ECM), high temperature
P0642 ECM‑8410 Power supply 5 volts Signal too low. Intermittent fault
P0642 ECM‑8410 Power supply 5 volts Signal too low. Permanent fault
P0643 ECM‑8410 Power supply 5 volts Signal too high. Intermittent fault
P0643 ECM‑8410 Power supply 5 volts Signal too high. Permanent fault
P0645 ECM‑6000 Air conditioning (A/C) relay, signal Signal missing. Intermittent fault
P0645 ECM‑6000 Air conditioning (A/C) relay, signal Signal missing. Permanent fault
P0646 ECM‑6000 Air conditioning (A/C) relay, signal Signal too low. Intermittent fault
P0646 ECM‑6000 Air conditioning (A/C) relay, signal Signal too low. Permanent fault
P0647 ECM‑6000 Air conditioning (A/C) relay, signal Signal too high. Intermittent fault
P0647 ECM‑6000 Air conditioning (A/C) relay, signal Signal too high. Permanent fault
P0650 ECM‑6B00 Malfunction indicator lamp (MIL) Signal missing. Intermittent signal fault
P0650 ECM‑6B00 Malfunction indicator lamp (MIL) Signal missing. Permanent signal fault
P0650 ECM‑6B00 Malfunction indicator lamp (MIL) Signal too low. Intermittent signal fault
P0650 ECM‑6B00 Malfunction indicator lamp (MIL) Signal too low. Permanent signal fault
P0650 ECM‑6B00 Malfunction indicator lamp (MIL) Signal too high. signal Intermittent fault
P0650 ECM‑6B00 Malfunction indicator lamp (MIL) Signal too high. Permanent signal fault
P0668 ECM‑7180 Temperature sensor control module Signal too high / signal too low. Intermittent fault
P0668 ECM‑7180 Temperature sensor control module Signal too high / signal too low. Permanent fault
P0669 ECM‑7180 Temperature sensor control module Signal too high / signal too low. Intermittent fault
P0669 ECM‑7180 Temperature sensor control module Signal too high / signal too low. Permanent fault
P0700 ECM‑530D Diagnostic trouble code (DTC) in another control module
P0727 ECM‑3100 Engine speed (RPM) sensor Signal missing. Intermittent fault
P0727 ECM‑3100 Engine speed (RPM) sensor Signal missing. Permanent fault
P0805 ECM‑9300 Clutch pedal sensor Faulty signal
P0807 ECM‑9300 Clutch pedal sensor Signal too low
P0808 ECM‑9300 Clutch pedal sensor Signal too high
P0863 ECM‑530B Control module communication
P1177 ECM‑268A Long‑term fuel trim
P1178 ECM‑268A Long‑term fuel trim
P1179 ECM‑268A Long‑term fuel trim Lower limit
P1187 ECM‑278A Faulty signal
P1188 ECM‑278A
P1189 ECM‑278A
P1234 ECM‑6814 Turbocharger (TC) control system
P1285 ECM‑913F Throttle unit Signal too high
P1286 ECM‑913C Throttle unit Faulty signal
P1287 ECM‑913C Throttle unit Faulty signal
P1293 ECM‑914F Throttle unit Faulty signal
P1480 ECM‑6100 Engine cooling fan (FC) control Faulty signal Faulty signal
P1481 ECM‑6110 Engine cooling fan (FC) relay Signal too low. Intermittent fault
P1481 ECM‑6110 Engine cooling fan (FC) relay Signal too low. Permanent fault
P1482 ECM‑6110 Engine cooling fan (FC) relay Signal too high. Intermittent fault
P1482 ECM‑6110 Engine cooling fan (FC) relay Signal too high. Permanent fault
P1526 ECM‑980A Engine control module (ECM). Intermittent fault Internal fault
P1526 ECM‑980A Engine control module (ECM). Permanent fault Internal fault
P1554 ECM‑801A System relay Faulty signal or signal missing
P1555 ECM‑801A System relay Faulty signal or signal
P1638 ECM‑715D Engine control module (ECM), high temperature
P1651 ECM‑981A Engine control module (ECM). Intermittent fault Internal fault
P1651 ECM‑981A Engine control module (ECM). Permanent fault Internal fault
P1652 ECM‑982A Engine control module (ECM). Intermittent fault Internal fault
P1652 ECM‑982A Engine control module (ECM). Permanent fault Internal fault
P1680 ECM‑720A Immobilizer communication Signal missing. Intermittent fault
P1680 ECM‑720A Immobilizer communication Signal missing. Permanent fault
P1721 ECM‑6220 Control module cooling fan
P1722 ECM‑6220 Control module cooling fan Signal too high
P1723 ECM‑6220 Control module cooling fan Signal too low
P2088 ECM‑6400 Intake camshaft reset valve Signal missing Signal too low or signal missing
P2089 ECM‑6400 Intake camshaft reset valve Signal too low or signal missing
P2090 ECM‑6410 Exhaust camshaft reset valve Signal too low or signal missing
P2091 ECM‑6410 Exhaust camshaft reset valve Signal too low or signal missing
P2101 ECM‑9100 Engine control module (ECM)
P2108 ECM‑919A Engine control module (ECM) Faulty signal
P2109 ECM‑918A Engine control module (ECM). Faulty signal Intermittent fault
P2109 ECM‑918A Engine control module (ECM). Permanent fault Internal fault
P2111 ECM‑91B7 Throttle unit
P2112 ECM‑91C7 Throttle unit Faulty signal
P2119 ECM‑9117 Throttle unit Faulty signal
P2121 ECM‑9540 Accelerator pedal (AP) position Faulty signal, sensor, digital signal
P2122 ECM‑9530 Accelerator pedal (AP) position Signal too low sensor, digital signal
P2123 ECM‑9530 Accelerator pedal (AP) position Signal too high sensor, digital signal
P2126 ECM‑9520 Accelerator pedal (AP) position Faulty signal sensor, analogy signal
P2127 ECM‑9520 Accelerator pedal (AP) position Signal too low sensor, analogy signal
P2128 ECM‑9520 Accelerator pedal (AP) position Signal too high sensor, analogy signal
P2131 ECM‑9400 Brake pedal sensor Faulty signal
P2135 ECM‑903C Throttle position (TP) sensor
P2177 ECM‑261A Long‑term fuel trim
P2178 ECM‑261A Long‑term fuel trim Upper limit Lower limit
P2179 ECM‑271A Long‑term fuel trim, bank 2 Upper limit
P2180 ECM‑271A Long‑term fuel trim, bank 2 Lower limit
P2187 ECM‑262A Long‑term fuel trim Upper limit
P2188 ECM‑262A Long‑term fuel trim Lower limit
P2189 ECM‑272A Long‑term fuel trim, bank 2 Upper limit
P2190 ECM‑272A Long‑term fuel trim, bank 2 Lower limit
P2191 ECM‑260A Long‑term fuel trim Upper limit
P2192 ECM‑260A Long‑term fuel trim Lower limit
P2193 ECM‑270A Long‑term fuel trim, bank 2 Upper limit
P2194 ECM‑270A Long‑term fuel trim, bank 2 Lower limit
P2232 ECM‑2A0A Rear heated oxygen sensor (HO2S) Faulty signal. Intermittent fault
P2232 ECM‑2A0A Rear heated oxygen sensor (HO2S) Faulty signal. Permanent fault
P2235 ECM‑2B0A Rear heated oxygen sensor bank 2 fault
P2300 ECM‑3300 Ignition coil cylinder 1, signal Signal too low. Intermittent fault
P2300 ECM‑3300 Ignition coil cylinder 1, signal Signal too low. Permanent fault
P2301 ECM‑3300 Ignition coil cylinder 1, signal Signal too high. Intermittent fault
P2301 ECM‑3300 Ignition coil cylinder 1, signal Signal too high. Permanent fault
P2303 ECM‑3310 Ignition coil cylinder 2, signal Signal too low. Intermittent fault
P2303 ECM‑3310 Ignition coil cylinder 2, signal Signal too low. Permanent fault
P2304 ECM‑3310 Ignition coil cylinder 2, signal Signal too high. Intermittent fault
P2304 ECM‑3310 Ignition coil cylinder 2, signal Signal too high. Permanent fault
P2306 ECM‑3320 Ignition coil cylinder 3, signal Signal too low. Intermittent fault
P2306 ECM‑3320 Ignition coil cylinder 3, signal Signal too low. Permanent fault
P2307 ECM‑3320 Ignition coil cylinder 3, signal Signal too high. Intermittent fault
P2307 ECM‑3320 Ignition coil cylinder 3, signal Signal too high. Permanent fault
P2309 ECM‑3330 Ignition coil cylinder 4, signal Signal too low. Intermittent fault
P2309 ECM‑3330 Ignition coil cylinder 4, signal Signal too low. Permanent fault
P2310 ECM‑3330 Ignition coil cylinder 4, signal Signal too high. Intermittent fault
P2310 ECM‑3330 Ignition coil cylinder 4, signal Signal too high. Permanent fault
P2312 ECM‑3340 Ignition coil cylinder 5, signal Signal too low. Intermittent fault
P2312 ECM‑3340 Ignition coil cylinder 5, signal Signal too low. Permanent fault
P2313 ECM‑3340 Ignition coil cylinder 5, signal Signal too high. Intermittent fault
P2313 ECM‑3340 Ignition coil cylinder 5, signal Signal too high. Permanent fault
P2400 ECM‑4024 Leak diagnostic unit, pump
P2401 ECM‑4024 Leak diagnostic unit, pump Signal missing
P2402 ECM‑4024 Leak diagnostic unit, pump Signal too low
P2404 ECM‑431D Leak diagnostic unit Signal too high
P2405 ECM‑431D Leak diagnostic unit Faulty signal
P2406 ECM‑431D Leak diagnostic unit Signal too low
P2407 ECM‑431D Leak diagnostic unit Signal too high
U0001 ECM‑E000 Control module, internal fault Signal missing
U0002 ECM‑E000 Control module, internal fault Faulty signal. Permanent fault
U0073 ECM‑E003 Control module, internal fault Faulty signal. Intermittent fault
U0073 ECM‑E003 Control module, internal fault Faulty signal. Permanent fault
13 responses to “Codes: 1999+ Volvos”
  1. lorraine says:
    My dashboard messages keep getting stuck and the windscreen wipers intermittently cannot be turned off when this happens the indicated do not work either. Used a diagnostic reader which displays code U1900. Any ideas anyone please?
  2. […] Fortunately, I found that BCM (brake control module) codes indicating a failed Yaw Sensor may not necessarily indicate a $500+ repair is on the horizon. In my case, water had not penetrated the Yaw Sensor housing. Rather, water had pooled in the cowling of the plastic electrical fitting that passed through the Yaw Sensor housing. This fitting contains the connection pins to which the harness is attached. Removal inspection showed green corrosion deposits on and in-between the pins. I assume that this somehow shorted the pins and lead to the Yaw Sensor failure codes. […]
  3. charles says:
    What is code p2115
  4. Norman says:
    Code: anti skip reduce engine performance. pls help out on this problem… Tq
  5. james says:
    I have four intermittant codes P1021, P1026, P1031, and P1054 on a volvo 1999v70 badse wagon with normally aspirated 5 cylinder 2.4l. the car only has 122K miles on it and is in excellent condition, seems to run smooth, cold a/c etc.. what are these codes? Thanks for the help!
  6. Bob says:
    I got a volvo-specific code P10181 but cannot find it in the above chart. Anyone know what it is? Also after replacing tone ring on LF axle and clearing ABS code 0011 I now can’t start the car – runs mometarily then dies – and I now have code ECM 720A. What do I need to do to get this sucker to run again! HEEELLP!
  7. manicmech says:
    does anyone have the rediness monitor reset proceedure for a 2001 volvo v7 xc
  8. DMcK says:
    My 2000 Volvo C70 has codes P0722 and P1618 which are not identified on this page: http://www.matthewsvolvosite.com/volvo-1999-and-newer-codes
  9. phil says:
    hi
    I would like to know what fault code 9AOA is
    my scanner is sayong vehicle behavior
    What does that mean
    Thanks
  10. andy says:
    I have a 2000 v70 xc t and the eml keeps coming on code reader says p1550 not listed on your list any idea what it is thanks
  11. Phil says:
    I have a engine ECU. Fault code SA. SPN. 5397. FMI. 31 can you tell me what it is
  12. Randy Oehlert says:
    My 1999 S 80 2.9 the check engine light staying on,it come on about a week ago as I was having turn around on a steep driveway ,is pulled on to the drive and because of traffic is had to quickly put it in reverse backed out quickly back on to the street quickly back into drive and go but when I went from drive and quickly into reverse something about the car didn’t feel right and soon as I was heading the right direction down the road in look down to check if any messages in the message center,because something about that quick turnaround didn’t feel right. Sure enough the check engine light was on.this is the first time that I have seen the light come on And Stay on. I went to 2 different auto parts places that connect there reader to check engine codes. Both places got the same thing. No codes at all.The light staying on but computer showing no codes and no problems. ?
    Where do I go from here.
    Also my air bag light staying on after installing a new battery 2 months ago. Must be something happened when changing battery?
    Also everything is starting the car the message center says alarm system problem. ???
    Car is running perfect, no problems at all starts easily, idles smooth with a/couple on or off ,cold start working perfectly. I can’t find a reason for the check engine light or the alarm system needs service and the SRS URGENT MESSAGE.
    forgot to mention the transmission working perfectly also, no problem.
    One thing that I don’t know what happened is the sun roof works sometimes not other times works perfect or not at all.And the same problem with the passenger side window. Works perfect or not at all.
    I’ve checked everything that I know of to check.
    No Volvo dealer here, closet is about 150 miles away.
    Thank you in advance for your help
