Volvo Diagnostic Code Lookup
volvo diagnostic code lookup
Need a diagnostic code lookup?
You can now get the definitions of Global OBD II (P0) and Enhanced OBD II (P1) Diagnostic Trouble Codes (DTCs) online. Select your vehicle and request the definition of your OBD II DTC. We in the 850 family who have 1996 and 1997 model years have it easy. Check Engine light comes on? We just plug in our code lookup readers and a magical system called OBD-II tells us what code(s) are causing the CE light. Same with 1998 model year Volvos, like S70, V70 and XC70 models. Then after that, the code lookup expanded from the OBD-II to include Volvo-specific codes that OBD-II readers cannot retrieve, although many overlap in meaning.
To start, the Ignition key must be in position II, engine not running. Open the hood. Locate the two diagnostic sockets just inboard of the washer fill cap. The “A” connector (shown above) has a jumper that is stored in the lid of the “A” diagnostic connector. The jumper is used for both diagnostic connectors.
Date October 26, 2005
18 responses to “Volvo Diagnostic Code Lookup”
  1. Debenham says:
    What does the code number 214 mean for a 1989, 240 Wagon?
    Also, where can we find all of the code interpretations for both the 1989 240 Wagon, and the 1991 940 sedan.
    Thank you and Happy New Year!
    Bob Debenham
  2. Leo says:
    Want to know what this code means P0756,P0733,P0422,P01618 thanks.
  3. greg garafola says:
    p0030 and p1238. im getting on a 99 s80 t6. what do these mean and where should i start. ty
  4. please i am haven problem with my s60 2oo5 and the diagnostic giving me is(CEM-1A62 C0MMUNICATION WITH THE ENGINE CONTROL MODULE ) SIGNAL MISSING.AND THE POSSIBLE SOURCE GIVING ME IS (1)NO POWER SUPPLY TO ENGINE CONTROL MODULE (2)OPEN CIRCUIT IN THE GROUND LEAD FOR THE ENGINE CONTROL MODULE (3)OPEN CIRCUIT IN THE WIRING FOR THE CAN HIGH SPEED NETWORK TO THE ENGINE CONTROL MODULE.AND I HAVE ALREADY CHECK THE NUMBER 1 AND 2 AND LIFT WITH THE 3 BUT I DON`T HAVE WIRING DIAGRAM.PLEASE I NEED THE WIRING DIAGRAM ONLY THE CAN HIGH SPEED HOW IT WORKS.THANK YOU.
  5. Lathressa says:
    What does 2.9L62.9L2917ccB6294S FIMFI GAS DOHC mean?
  6. joed says:
    re: 2000 Volvo S70 GLT A SR 2.4 liter, 190 hp, 5cyl hi torque, lo rev
    I’m reading diag codes: P1171 and P1550. Can someone tell me what these tbl codes are saying? thanks
  7. Le Taff says:
    What does the ECU code MID128 SID146 FMI5 mean? It is showing on my 2006 Volvo 12 liter moter on my semi…please help!
  8. stephan buckley says:
    I went to get my car smog cert. it didn’t pass and they gave me a code of P0030 for my 2004 C70. What does that mean?
  9. Austin Cranfill says:
    I need to know what the codes P0014 and P1550 mean for a 1999 volvo V70 XC. I also have the blinking lights on the climate control (amber Recirc and OFF) but the AC still works and the check engine light has come on and gone off the last three days. The local autozone was able to give me these codes via their handheld reader but returned no results when they took it inside to look the codes up on their system. 8(
  10. RB Booker says:
    like to know the codes for check engene light fore 2004 volvo s60
  11. Rafael G. Melendez says:
    What does codes P0101, P0133, P0442 mean?
  12. Alex mandovha says:
    Please help me with the meaning of a sign appearing on the dashboard of a Volvo s80 t6 2000 model as two wheels as seen from the back of the car
  13. Jim says:
    What does the code p1618 mean on a v70 cross country wagon 2001?
  14. brian says:
    what does 444 code mean for 2001 s80 2.9 sedan?
  15. Gary says:
    Have a 2005 S80…60,000 miles. P0456,P0442,P0700, and P0734 popped up coming home from a trip.Towed her home a hundred miles out! Insight into these please?
  16. i have a 2001 c70 and check engine light is on the code
    p1332 from a little research is a solenoid. is this correct , where is the location of it in the car and can it be bought at parst store and app. how much. how hard to install/
  17. steve says:
    I have 5 code po1113 po14 po344 po354 po300 I need to no what is the diaqnostic
  18. What does the codes means p0785 p0716 says:
    785
