Volvo Repair Database
Volvo Engine Oil Change — The Easy Way
Volvo 850, S70, V70, XC70, C70 gen.1 easy oil change DIYI wrote a short and sweet DIY for Oil Change using wood ramps and no need to jack the car up. Basically as sweet and simple as possible! You can do this for under 30 minutes.
[Have a newer Volvo? See this S80, S60 and V70 2001+ Oil Change DIY forum topic.]
NOTE: Best is to do this with warm engine, so after a trip somewhere, park it at home and let it cool down for 30 minutes or so. I change my oil twice a year, or about 5K-6K miles. I don’t want to get into a debate about change interval (Maintenance minder, 5K, 7.5K, 10K, and so on). This is what I do and is what I believe in: every 5-6K miles or so.
* WINTER: 5W30 Synthetic Oil for easier cold start.
* SUMMER: 10W30 Synthetic Oil (Standard Oil is fine too).
DIY: 98 V70 Engine Oil Change (& ATF Change): the Easy Way!
  1. Spark Plug Change Tutorial: Volvo 850, S70, V70, XC70, C70
  2. Which Oil for Turbo Engine?
  3. 850 and V/S70 Shock Change Checklist
  4. S80 1G 6Cyl Auto Transmission Fluid & Filter Change How-To
  5. Replace Upper Engine Mount w/ Polyurethane Bushing
This entry was posted in Basic Maintenance, Fluids, Lubricants, Additives & Sealers, Saving Money and tagged , , , , , , , , , , . Bookmark the permalink.
