Volvo Repair Category: Volvo Repair Database
Boost Gauge Install DIY
How to Install a Boost Gauge This Volvo Forum topic covers installation of a boost gauge. Your model of Volvo might be different from the photos and description, but the concepts are there. Wiring, routing the vacuum tube, it’s all … Continue reading
Wiper Linkage Adjustment
After dealing with what was thought to be a driver’s side wiper arm issue (common), the issue resulted in replacement of the entire wiper linkage or transmission (also known as the “frame.”). During the replacement process, there was huge confusion … Continue reading
Aftermarket Heated Seats
“I don’t handle the cold well, and this is our second Ohio Winter. After last year I swore I’d have remote start and heated seats before I went through another Ice Age. I got the remote start done back in … Continue reading
Antifreeze (coolant) circulates through the engine to keep it at its ideal running temperature. It’s water-based. The problem is that if it’s pure water, it freezes at 0C or 32F, and it will literally crack your engine. Yes, freezing water … Continue reading
S80, V70 (2001+), S60, XC90 Blower Motor Repair Tutorial
I’ve had trouble with my interior climate control blower fan squealing at startup, more persistently when it’s cold out. The problem has become more frequent over the past year, so I finally decided it was time to replace the blower … Continue reading
Volvo Engine Oil Change — The Easy Way
I wrote a short and sweet DIY for Oil Change using wood ramps and no need to jack the car up. Basically as sweet and simple as possible! You can do this for under 30 minutes. [Have a newer Volvo? … Continue reading
PCV Job for V70 and S70 Non-turbo
Since mine is a Non-Turbo, there are minor different designs compared with Turbo Models. In addition, I will point to areas of possible problems for people. – Read the above write-up for Turbo. – Copy Radio AM FM channels, disconnect … Continue reading
Torquing Control Arm Bolts Using A Jack
I have installed new control arms and I am at the point where I need to torque the bushing bolts. I have my car up on ramps but that gives me very limited access to the nuts, to work my … Continue reading
No Brakes When Cold, Volvo V70
No Brakes Symptoms After a startup when engine is cold there is no brake assist, the brake pedal feels very hard, braking efficiency is very low and for some reason it feels worse when driving in reverse. No Brakes Solution Vacuum … Continue reading
Register
Search
Help
