Volvo S40 and V40
Half Volvo, half Mitsubishi, the Volvo S40 and V40 compact car debuted in 1995, and was completely redesigned and relaunched in 2004.
The first generation came with variety of 4-cylinder engines, including 1.6, 1.8, 1.9 and 2.0 gasoline engines, the largest being offered with two turbo choices: 2.0T and T4 (high pressure turbo). In addition to the dizzying array of thrust options, Europe got a 1.9 liter diesel. The United States market got exactly one engine: the 1.9 with the low-pressure turbo.
Register
Search
Help
I have heard that mitsubishi and volvo came together on this one, but no where can I find any Japanese parts other than the trans, which BTW is the only issue on the car for me anyway. It slips too much IMO. But that is the case with most automatic transmissions anyway so no big deal there. I have seen the mitsubishi version and it does share the body but it is made in netherlands as well so half japanese is not accurate. 90% european contents makes this a stalwart car, But the only down turn is the trans as is the case with most Japanese transmissions used on several European makes.
Dear Sir/Madam,
I own a volvo S40 and it’s difficult to get good service in Uganda because we don’t have a very good volvo specialist & technician. I would like to stock genuine volvo parts starting with service parts. How much money do I need to start this business?
My Cell Phone Number is +256772121808
Dear Sir,
The following Relates to a, 1998 Volvo V40 S/Wagon front r/h side Drive shaft seal on the gearbox side
I am looking for the physical width, inside & outside measurement of the front r/hand side drive shaft seal
were the CV-joint enters the transmission box. It’s leaking gearbox oil through there.
Kind regards
Daan van tonder
I have a 2001 S40 and I am trying to do a diagnostic test on the car, but cannot locate where it needs to be pluged in to do the test. I have looked under that dash and also under the hood and still have not found it
If its a RH drive its located on the side area of the center console close to the floor passenger side
my 2000volvo wont start have no spark ign. coils ok.have12v on red coil wire s40 1.9t
I recently purchased a 2001 volvo s40D and have tried every site to purchase a haynes manual there is none even on the publish list can anybody tell me why?
I would like to know the best way to install a i57 cold air intake on my 2000 S40? Any help would be appreciated.
Hi
Ijust by an Volvo s40 2001 yesterday.and suddenly the heater turn off and it didnt turn on again.I dont know what should I do.It was working just fine.
any help??????????
