OBD II is a diagnostics system designed to meet statutory requirements. A standardized instrument for fault-tracing can be plugged in to the data link connector (DLC) (OBD II socket) to read diagnostic trouble codes (DTCs) and system parameters.
OBD II contains only emissions related diagnostic trouble codes (DTCs) and parameters. It cannot provide the comprehensive range of information available from the Volvo On-board diagnostics system. Volvo has its own diagnostic trouble code (DTC) designations that adhere to the in-house Volvo On-board Diagnostics protocol (called DII from model year 1999).
The table below is a conversion table between standardised diagnostic trouble codes (DTCs) (SAE/ISO) and the equivalent Volvo diagnostic trouble codes (DTCs) (DII). SAE/ISO diagnostic trouble code (DTC): Standardized diagnostic trouble code (DTC) according to SAE J2012/ISO 15031-6. The diagnostic trouble code (DTC) can be read off on vehicles with standardised on-board diagnostic systems for emissions related faults, certified in accordance with OBD II.
Please help us add to this
| SAE/ISO trouble code | Volvo trouble code | Designation | Fault |
| P0010 | ECM-6400 | Intake camshaft reset valve | Signal too low or signal missing |
| P0011 | ECM-640A | Camshaft control, intake | Faulty signal |
| P0013 | ECM-6410 | Exhaust camshaft reset valve | Signal too low or signal missing |
| P0014 | ECM-641A | Camshaft control, exhaust | Faulty signal |
| P0016 | ECM-643A | Camshaft position, intake | Signal too low |
| P0016 | ECM-643A | Camshaft position, intake | Signal too high |
| P0017 | ECM-644A | Camshaft position, exhaust | Signal too low |
| P0017 | ECM-644A | Camshaft position, exhaust | Signal too high |
| P0030 | ECM-2810 | Front heated oxygen sensor (HO2S), preheating | Signal missing. Intermittent fault |
| P0030 | ECM-2810 | Front heated oxygen sensor (HO2S), preheating | Signal missing. Permanent fault |
| P0031 | ECM-2810 | Front heated oxygen sensor (HO2S), preheating | Signal too low. Intermittent fault |
| P0031 | ECM-2810 | Front heated oxygen sensor (HO2S), preheating | Signal too low. Permanent fault |
| P0032 | ECM-2810 | Front heated oxygen sensor (HO2S), Signal too high. preheating | Intermittent fault |
| P0032 | ECM-2810 | Front heated oxygen sensor (HO2S), preheating | Signal too high. Permanent fault |
| P0036 | ECM-2A20 | Heated oxygen sensor (HO2S) bank | Signal missing 1, preheating |
| P0037 | ECM-2A20 | Heated oxygen sensor (HO2S) bank | Signal too low 1, preheating |
| P0038 | ECM-2A20 | Heated oxygen sensor (HO2S) bank | Signal too high 1, preheating |
| P0040 | ECM-280C | Front heated oxygen sensors (HO2S) Faulty signal | undefined |
| P0050 | ECM-2910 | Front heated oxygen sensor (HO2S) | Signal missing preheating, bank 2 |
| P0051 | ECM-2910 | Front heated oxygen sensor (HO2S) | Signal too low preheating, bank 2 |
| P0052 | ECM-2910 | Front heated oxygen sensor (HO2S) | Signal too high preheating, bank 2 |
| P0056 | ECM-2B20 | Heated oxygen sensor (HO2S) bank | Signal missing 2, preheating |
| P0057 | ECM-2B20 | Heated oxygen sensor (HO2S) bank | Signal too low 2, preheating |
| P0058 | ECM-2B20 | Heated oxygen sensor (HO2S) bank | Signal too high 2, preheating |
| P0071 | ECM-1100 | Outer temperature sensor | Faulty signal |
| P0072 | ECM-1100 | Outer temperature sensor | Signal too low |
| P0073 | ECM-1100 | Outer temperature sensor | Signal too high |
| P0101 | ECM-130A | Intake air leakage | Faulty signal |
| P0102 | ECM-1300 | Mass air flow (MAF) sensor | Flow too low. Intermittent fault |
| P0102 | ECM-1300 | Mass air flow (MAF) sensor | Flow too low. Permanent fault |
| P0103 | ECM-1300 | Mass air flow (MAF) sensor | Flow too high. Intermittent fault |
| P0103 | ECM-1300 | Mass air flow (MAF) sensor | Flow too high. Permanent fault |
| P0105 | ECM-1000 | Control module | Faulty signal |
| P0107 | ECM-1000 | Control module | Signal too high / signal too low. Intermittent fault |
| P0107 | ECM-1000 | Control module | Signal too high / signal too low. Permanent fault |
| P0108 | ECM-1000 | Control module | Signal too high / signal too low. Intermittent fault |
| P0108 | ECM-1000 | Control module | Signal too high / signal too low. Permanent fault |
| P0111 | ECM-1200 | Intake air temperature (IAT) inlet | Faulty signal |
| P0112 | ECM-1200 | Intake air temperature (IAT) inlet | Signal too high. Intermittent fault |
| P0112 | ECM-1200 | Intake air temperature (IAT) inlet | Signal too high. Permanent fault |
| P0113 | ECM-1200 | Intake air temperature (IAT) inlet | Signal too low. Intermittent fault |
| P0113 | ECM-1200 | Intake air temperature (IAT) inlet | Signal too low. Permanent fault |
| P0121 | ECM-9150 | Throttle unit, potentiometer 1 | Faulty signal |
| P0122 | ECM-9150 | Throttle unit, potentiometer 1 | Signal too low |
| P0123 | ECM-9150 | Throttle unit, potentiometer 1 | Signal too high |
| P0128 | ECM-201A | Thermostat | Faulty signal |
| P0130 | ECM-280A | Front heated oxygen sensor (HO2S), faulty signal | Signal missing. Intermittent fault |
| P0130 | ECM-280A | Front heated oxygen sensor (HO2S), faulty signal | Signal missing. Permanent fault |
| P0132 | ECM-280A | Front heated oxygen sensor (HO2S), Signal too high. faulty signal | Intermittent fault |
| P0132 | ECM-280A | Front heated oxygen sensor (HO2S), faulty signal | Signal too high. Permanent fault |
| P0133 | ECM-280A | Front heated oxygen sensor (HO2S), faulty signal | Signal too low. Intermittent fault |
| P0133 | ECM-280A | Front heated oxygen sensor (HO2S), faulty signal | Signal too low. Permanent fault |
| P0134 | ECM-280A | Front heated oxygen sensor (HO2S) | Faulty signal. Intermittent fault |
| P0134 | ECM-280A | Front heated oxygen sensor (HO2S) | Faulty signal. Permanent fault |
| P0135 | ECM-290A | Front heated oxygen sensor (HO2S), preheating | Faulty signal. Intermittent fault |
| P0135 | ECM-290A | Front heated oxygen sensor (HO2S), preheating | Faulty signal. Permanent fault |
| P0136 | ECM-2A0A | Rear heated oxygen sensor (HO2S) | Signal missing. Intermittent fault |
| P0136 | ECM-2A0A | Rear heated oxygen sensor (HO2S) | Signal missing. Permanent fault |
| P0137 | ECM-2A0A | Rear heated oxygen sensor (HO2S) | undefined |
| P0138 | ECM-2A0A | Rear heated oxygen sensor (HO2S) | Signal too high. Intermittent fault |
| P0138 | ECM-2A0A | Rear heated oxygen sensor (HO2S) | Signal too high. Permanent fault |
| P0140 | ECM-2A1A | Rear heated oxygen sensor (HO2S) | Signal too low aging |
| P0140 | ECM-2A1A | Rear heated oxygen sensor (HO2S) | Signal too high aging |
| P0140 | ECM-2A1A | Rear heated oxygen sensor (HO2S) | Signal missing aging |
| P0141 | ECM-2A2A | Rear heated oxygen sensor (HO2S), | Faulty signal preheating |
| P0150 | ECM-290A | Front heated oxygen sensor (HO2S), bank 2 | Signal missing. Intermittent fault |
| P0150 | ECM-290A | Front heated oxygen sensor (HO2S), bank 2 | Signal missing. Permanent fault |
| P0152 | ECM-290A | Front heated oxygen sensor (HO2S), Signal too high bank 2 | undefined |
| P0153 | ECM-290A | Front heated oxygen sensor (HO2S), bank 2 | Signal too low. Intermittent fault |
| P0153 | ECM-290A | Front heated oxygen sensor (HO2S), bank 2 | Signal too low. Permanent fault |
| P0154 | ECM-290A | Front heated oxygen sensor (HO2S), bank 2 | Faulty signal. Intermittent fault |
| P0154 | ECM-290A | Front heated oxygen sensor (HO2S), bank 2 | Faulty signal. Permanent fault |
| P0155 | ECM-2910 | Front heated oxygen sensor (HO2S), bank 2 | Faulty signal. Intermittent preheating fault |
| P0155 | ECM-2910 | Front heated oxygen sensor (HO2S), bank 2 | Faulty signal. Permanent preheating fault |
| P0156 | ECM-2B0A | Rear heated oxygen sensor (HO2S), bank 2 | Signal missing. Intermittent fault |
| P0156 | ECM-2B0A | Rear heated oxygen sensor (HO2S), bank 2 | Signal missing. Permanent fault |
| P0157 | ECM-2B0A | Rear heated oxygen sensor (HO2S), bank 2 | undefined |
| P0158 | ECM-2B0A | Rear heated oxygen sensor (HO2S), bank 2 | Signal too high. Intermittent fault |
| P0158 | ECM-2B0A | Rear heated oxygen sensor (HO2S), bank 2 | Signal too high. Permanent fault |
| P0160 | ECM-2B1A | Rear heated oxygen sensor (HO2S) | Signal too low ageing, bank 2 |
| P0160 | ECM-2B1A | Rear heated oxygen sensor (HO2S) | Signal too high ageing, bank 2 |
| P0160 | ECM-2B1A | Rear heated oxygen sensor (HO2S) | Signal missing ageing, bank 2 |
| P0161 | ECM-2B2A | Rear heated oxygen sensor (HO2S) | Faulty signal preheating, bank 2 |
| P1729 | ECM-9170 | Throttle unit | Faulty signal |
| P0201 | ECM-2310 | Injector 1 | Signal missing. Intermittent fault |
| P0201 | ECM-2310 | Injector 1 | Signal missing. Permanent fault |
| P0202 | ECM-2320 | Injector 2 | Signal missing. Intermittent fault |
| P0202 | ECM-2320 | Injector 2 | Signal missing. Permanent fault |
| P0203 | ECM-2330 | Injector 3 | Signal missing. Intermittent fault |
| P0203 | ECM-2330 | Injector 3 | Signal missing. Permanent fault |
| P0204 | ECM-2340 | Injector 4 | Signal missing. Intermittent fault |
| P0204 | ECM-2340 | Injector 4 | Signal missing. Permanent fault |
| P0205 | ECM-2350 | Injector 5 | Signal missing. Intermittent fault |
| P0205 | ECM-2350 | Injector 5 | Signal missing. Permanent fault |
| P0206 | ECM-2360 | Injector 6 | Signal missing. Intermittent fault |
| P0206 | ECM-2360 | Injector 6 | Signal missing. Permanent fault |
| P0221 | ECM-9160 | Throttle unit, potentiometer 2 | Faulty signal |
| P0222 | ECM-9160 | Throttle unit, potentiometer 2 | Signal too low |
| P0223 | ECM-9160 | Throttle unit, potentiometer 2 | Signal too high |
| P0230 | ECM-2400 | Fuel pump (FP) relay | Signal missing. Intermittent fault |
| P0230 | ECM-2400 | Fuel pump (FP) relay | Signal missing. Permanent fault |
| P0231 | ECM-2400 | Fuel pump (FP) relay | Signal too low. Intermittent fault |
| P0231 | ECM-2400 | Fuel pump (FP) relay | Signal too low. Permanent fault |
| P0232 | ECM-2400 | Fuel pump (FP) relay | Signal too high. Intermittent fault |
| P0232 | ECM-2400 | Fuel pump (FP) relay | Signal too high. Permanent fault |
| P0234 | ECM-6805 | Turbocharger (TC) control valve, | Pressure too high boost pressure fault |
| P0235 | ECM-1600 | Boost pressure sensor | Faulty signal |
| P0236 | ECM-170F | Atmospheric pressure sensor / | Faulty signal boost pressure sensor range check |
| P0237 | ECM-1600 | Boost pressure sensor | Signal too low |
| P0238 | ECM-1600 | Boost pressure sensor | Signal too high |
| P0243 | ECM-6800 | Turbocharger (TC) control valve | Signal missing. Intermittent fault |
| P0243 | ECM-6800 | Turbocharger (TC) control valve | Signal missing. Permanent fault |
| P0245 | ECM-6800 | Turbocharger (TC) control valve | Signal too low. Intermittent fault |
| P0245 | ECM-6800 | Turbocharger (TC) control valve | Signal too low. Permanent fault |
| P0246 | ECM-6800 | Turbocharger (TC) control valve | Signal too high. Intermittent fault |
| P0246 | ECM-6800 | Turbocharger (TC) control valve | Signal too high. Permanent fault |
| P0261 | ECM-2310 | Injector 1 | Signal too low. Intermittent fault |
| P0261 | ECM-2310 | Injector 1 | Signal too low. Permanent fault |
| P0262 | ECM-2310 | Injector 1 | Signal too high. Intermittent fault |
| P0262 | ECM-2310 | Injector 1 | Signal too high. Permanent fault |
| P0264 | ECM-2320 | Injector 2 | Signal too low. Intermittent fault |
| P0264 | ECM-2320 | Injector 2 | Signal too low. Permanent fault |
| P0265 | ECM-2320 | Injector 2 | Signal too high. Intermittent fault |
| P0265 | ECM-2320 | Injector 2 | Signal too high. Permanent fault |
| P0267 | ECM-2330 | Injector 3 | Signal too low. Intermittent fault |
| P0267 | ECM-2330 | Injector 3 | Signal too low. Permanent fault |
| P0268 | ECM-2330 | Injector 3 | Signal too high. Intermittent fault |
| P0268 | ECM-2330 | Injector 3 | Signal too high. Permanent fault |
| P0270 | ECM-2340 | Injector 4 | Signal too low. Intermittent fault |
| P0270 | ECM-2340 | Injector 4 | Signal too low. Permanent fault |
| P0271 | ECM-2340 | Injector 4 | Signal too high. Intermittent fault |
| P0271 | ECM-2340 | Injector 4 | Signal too high. Permanent fault |
| P0273 | ECM-2350 | Injector 5 | Signal too low. Intermittent fault |
| P0273 | ECM-2350 | Injector 5 | Signal too low. Permanent fault |
| P0274 | ECM-2350 | Injector 5 | Signal too high. Intermittent fault |
| P0274 | ECM-2350 | Injector 5 | Signal too high. Permanent fault |
| P0276 | ECM-2360 | Injector 6 | Signal too low. Intermittent fault |
| P0276 | ECM-2360 | Injector 6 | Signal too low. Permanent fault |
| P0277 | ECM-2360 | Injector 6 | Signal too high. Intermittent fault |
| P0277 | ECM-2360 | Injector 6 | Signal too high. Permanent fault |
| P0299 | ECM-6806 | Turbocharger (TC) control valve, | Pressure too low flow fault |
| P0300 | ECM-3503 | Misfire, at least one cylinder | Emissions impact / catalytic converter damage |
| P0301 | ECM-3513 | Misfire cylinder 1 | Emissions impact / catalytic converter damage |
| P0302 | ECM-3523 | Misfire cylinder 2 | Emissions impact / catalytic converter damage |
| P0303 | ECM-3533 | Misfire cylinder 3 | Emissions impact / catalytic converter damage |
| P0304 | ECM-3543 | Misfire cylinder 4 | Emissions impact / catalytic converter damage |
| P0305 | ECM-3553 | Misfire cylinder 5 | Emissions impact / catalytic converter damage |
| P0306 | ECM-3563 | Misfire cylinder 6 | Emissions impact / catalytic converter damage |
| P0324 | ECM-3400 | Knock sensor (KS), test pulse | Signal too high / signal too low. Intermittent fault |
| P0324 | ECM-3400 | Knock sensor (KS), test pulse | Signal too high / signal too low. Permanent fault |
| P0324 | ECM-34E0 | Knock sensor (KS), offset | Signal too high / signal too low. Intermittent fault |
| P0324 | ECM-34E0 | Knock sensor (KS), offset | Signal too high / signal too low. Permanent fault |
| P0327 | ECM-3410 | Knock sensor (KS), front | Signal too low. Intermittent fault |
| P0327 | ECM-3410 | Knock sensor (KS), front | Signal too low. Permanent fault |
| P0328 | ECM-3410 | Knock sensor (KS), front | Signal too high. Intermittent fault |
| P0328 | ECM-3410 | Knock sensor (KS), front | Signal too high. Permanent fault |
| P0332 | ECM-3420 | Knock sensor (KS), rear | Signal too low. Intermittent fault |
| P0332 | ECM-3420 | Knock sensor (KS), rear | Signal too low. Permanent fault |
| P0333 | ECM-3420 | Knock sensor (KS), rear | Signal too high. Intermittent fault |
| P0333 | ECM-3420 | Knock sensor (KS), rear | Signal too high. Permanent fault |
| P0335 | ECM-5200 | Engine speed (RPM) sensor | Signal missing |
| P0336 | ECM-5200 | Engine speed (RPM) sensor | Faulty signal |
| P0337 | ECM-5200 | Engine speed (RPM) sensor | Signal too low |
| P0338 | ECM-5200 | Engine speed (RPM) sensor | Signal too high |
| P0340 | ECM-3000 | Camshaft position (CMP) sensor, intake | Faulty signal or signal missing |
| P0342 | ECM-3000 | Camshaft position (CMP) sensor, intake | Signal too low. Intermittent fault |
| P0342 | ECM-3000 | Camshaft position (CMP) sensor, intake | Signal too low. Permanent intakefault |
| P0343 | ECM-3000 | Camshaft position (CMP) sensor, intake | Signal too high. Intermittent fault |
| P0343 | ECM-3000 | Camshaft position (CMP) sensor, Permanent intake | Signal too high. fault |
| P0344 | ECM-3000 | Camshaft position (CMP) sensor, | Faulty signal or signal intakemissing |
| P0345 | ECM-3010 | Camshaft position (CMP) sensor, | Faulty signal or signal exhaustmissing |
| P0347 | ECM-3010 | Camshaft position (CMP) sensor, | Signal too low exhaust |
| P0348 | ECM-3010 | Camshaft position (CMP) sensor, | Signal too high exhaust |
| P0349 | ECM-3010 | Camshaft position (CMP) sensor, | Faulty signal or signal exhaustmissing |
| P0351 | ECM-3300 | Ignition coil cylinder 1, signal | Signal missing. Intermittent fault |
| P0351 | ECM-3300 | Ignition coil cylinder 1, signal | Signal missing. Permanent fault |
| P0352 | ECM-3310 | Ignition coil cylinder 2, signal | Signal missing. Intermittent fault |
| P0352 | ECM-3310 | Ignition coil cylinder 2, signal | Signal missing. Permanent fault |
| P0353 | ECM-3320 | Ignition coil cylinder 3, signal | Signal missing. Intermittent fault |
| P0353 | ECM-3320 | Ignition coil cylinder 3, signal | Signal missing. Permanent fault |
| P0354 | ECM-3330 | Ignition coil cylinder 4, signal | Signal missing. Intermittent fault |
| P0354 | ECM-3330 | Ignition coil cylinder 4, signal | Signal missing. Permanent fault |
| P0355 | ECM-3340 | Ignition coil cylinder 5, signal | Signal missing. Intermittent fault |
| P0355 | ECM-3340 | Ignition coil cylinder 5, signal | Signal missing. Permanent fault |
| P0420 | ECM-4801 | Three-way catalytic converter (TWC) Intermittent fault efficiency, bank 1 | Intermittent fault |
| P0420 | ECM-4801 | Three-way catalytic converter (TWC) Permanent fault efficiency, bank 1 | Permanent fault |
| P0430 | ECM-4901 | Three-way catalytic converter (TWC) Intermittent fault efficiency, bank 2 | Intermittent fault |
| P0430 | ECM-4901 | Three-way catalytic converter (TWC) Permanent fault efficiency, bank 2 | Permanent fault |
| P0443 | ECM-4000 | Evaporative emission system (EVAP) valve | Signal missing. Intermittent fault |
| P0443 | ECM-4000 | Evaporative emission system (EVAP) valve | Signal missing. Permanent valvefault |
| P0444 | ECM-4000 | Evaporative emission system (EVAP) valve | Signal too high. Intermittent fault |
| P0444 | ECM-4000 | Evaporative emission system (EVAP) valve | Signal too high. Permanent valvefault |
| P0445 | ECM-4000 | Evaporative emission system (EVAP) valve | Signal too low. Intermittent fault |
| P0445 | ECM-4000 | Evaporative emission system (EVAP) valve | Signal too low. Permanent valvefault |
| P0446 | ECM-4010 | Leak diagnostic unit, valve | Signal too high |
| P0447 | ECM-4010 | Leak diagnostic unit, valve | Signal missing |
| P0448 | ECM-4010 | Leak diagnostic unit, valve | Signal too low |
| P0455 | ECM-400C | Fuel tank system, leakage | undefined |
| P0456 | ECM-400C | Fuel tank system, leakage | undefined |
| P0457 | ECM-4338 | Fuel tank filler cap missing | undefined |
| P0460 | ECM-405C | Fuel level sensor | undefined |
| P0461 | ECM-4050 | Fuel level sensor | Faulty signal |
| P0462 | ECM-4050 | Fuel level sensor | Signal too low |
| P0463 | ECM-4050 | Fuel level sensor | Signal too high |
| P0464 | ECM-4050 | Fuel level sensor | Signal missing |
| P0480 | ECM-6110 | Engine cooling fan (FC) relay | Signal missing. Intermittent fault |
| P0480 | ECM-6110 | Engine cooling fan (FC) relay | Signal missing. Permanent fault |
| P0483 | ECM-6100 | Engine cooling fan (FC) control | Faulty signal module |
| P0484 | ECM-6100 | Engine cooling fan (FC) control | Faulty signal module |
| P0485 | ECM-6100 | Engine cooling fan (FC) control | Faulty signal module |
| P0496 | ECM-4007 | Evaporative emission system (EVAP) valve | Signal too high |
| P0497 | ECM-4007 | Evaporative emission system (EVAP) valve | Signal too low |
| P0500 | ECM-510F | Speed signal | undefined |
| P0506 | ECM-990A | Idle air control (IAC) | Faulty signal |
| P0507 | ECM-990A | Idle air control (IAC) | Faulty signal |
| P0530 | ECM-5000 | A/C pressure sensor | Signal missing. Intermittent fault |
| P0530 | ECM-5000 | A/C pressure sensor | Signal missing. Permanent fault |
| P0532 | ECM-5000 | A/C pressure sensor | Signal too low. Intermittent fault |
| P0532 | ECM-5000 | A/C pressure sensor | Signal too low. Permanent fault |
| P0533 | ECM-5000 | A/C pressure sensor | Signal too high. Intermittent fault |
| P0533 | ECM-5000 | A/C pressure sensor | Signal too high. Permanent fault |
| P0560 | ECM-8010 | Battery voltage | Faulty signal |
| P0562 | ECM-8010 | Battery voltage | Signal too low |
| P0563 | ECM-8010 | Battery voltage | Signal too high |
| P0564 | ECM-928C | Control module, communication fault | Faulty signal |
| P0571 | ECM-9400 | Brake pedal sensor | Signal missing |
| P0573 | ECM-9400 | Brake pedal sensor | Signal too high |
| P0579 | ECM-928C | Control module, communication | Faulty signal fault |
| P0580 | ECM-928C | Control module, communication | Faulty signal fault |
| P0581 | ECM-928C | Control module, communication | Faulty signal fault |
| P0602 | ECM-531D | Control module, internal fault | undefined |
| P0604 | ECM-9050 | RAM memory fault | Internal fault. Intermittent fault |
| P0604 | ECM-9050 | RAM memory fault | Internal fault. Permanent fault |
| P0605 | ECM-9060 | ROM memory fault | Internal fault. Intermittent fault |
| P0605 | ECM-9060 | ROM memory fault | Internal fault. Permanent fault |
| P0606 | ECM-9070 | Control module, internal fault | Intermittent fault |
| P0606 | ECM-9070 | Control module, internal fault | Permanent fault |
| P0607 | ECM-711A | Engine control module (ECM), internal fault | Signal too high / signal too low. Intermittent fault |
| P0607 | ECM-711A | Engine control module (ECM), internal fault | Signal too high / signal too low. Permanent fault |
| P0630 | ECM-720A | Immobilizer communication | Faulty signal. Intermittent fault |
| P0630 | ECM-720A | Immobilizer communication | Faulty signal. Permanent fault |
| P0638 | ECM-91A7 | Throttle unit | Faulty signal |
| P0634 | ECM-716D | Engine control module (ECM), high temperature | undefined |
| P0642 | ECM-8410 | Power supply 5 volts | Signal too low. Intermittent fault |
| P0642 | ECM-8410 | Power supply 5 volts | Signal too low. Permanent fault |
| P0643 | ECM-8410 | Power supply 5 volts | Signal too high. Intermittent fault |
| P0643 | ECM-8410 | Power supply 5 volts | Signal too high. Permanent fault |
| P0645 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal missing. Intermittent fault |
| P0645 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal missing. Permanent fault |
| P0646 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal too low. Intermittent fault |
| P0646 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal too low. Permanent fault |
| P0647 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal too high. Intermittent fault |
| P0647 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal too high. Permanent fault |
| P0650 | ECM-6B00 | Malfunction indicator lamp (MIL), Intermittent signal | Signal missing. fault |
| P0650 | ECM-6B00 | Malfunction indicator lamp (MIL), Permanent signal | Signal missing. fault |
| P0650 | ECM-6B00 | Malfunction indicator lamp (MIL), Intermittent signal | Signal too low. fault |
| P0650 | ECM-6B00 | Malfunction indicator lamp (MIL), Permanent signal | Signal too low. fault |
| P0650 | ECM-6B00 | Malfunction indicator lamp (MIL), signal | Signal too high. Intermittent fault |
| P0650 | ECM-6B00 | Malfunction indicator lamp (MIL), Permanent signal | Signal too high. fault |
| P0668 | ECM-7180 | Temperature sensor control module | Signal too high / signal too low. Intermittent fault |
| P0668 | ECM-7180 | Temperature sensor control module | Signal too high / signal too low. Permanent fault |
| P0669 | ECM-7180 | Temperature sensor control module | Signal too high / signal too low. Intermittent fault |
| P0669 | ECM-7180 | Temperature sensor control module | Signal too high / signal too low. Permanent fault |
| P0700 | ECM-530D | Diagnostic trouble code (DTC) in another control module | undefined |
| P0727 | ECM-3100 | Engine speed (RPM) sensor | Signal missing. Intermittent fault |
| P0727 | ECM-3100 | Engine speed (RPM) sensor | Signal missing. Permanent fault |
| P0805 | ECM-9300 | Clutch pedal sensor | Faulty signal |
| P0807 | ECM-9300 | Clutch pedal sensor | Signal too low |
| P0808 | ECM-9300 | Clutch pedal sensor | Signal too high |
| P0863 | ECM-530B | Control module communication | undefined |
| P1177 | ECM-268A | Long-term fuel trim | Upper limit |
| P1178 | ECM-268A | Long-term fuel trim | Lower limit |
| P1179 | ECM-268A | Long-term fuel trim | Faulty signal |
| P1187 | ECM-278A | undefined | undefined |
| P1188 | ECM-278A | undefined | undefined |
| P1189 | ECM-278A | undefined | undefined |
| P1234 | ECM-6814 | Turbocharger (TC) control system | Signal too high |
| P1285 | ECM-913F | Throttle unit | Faulty signal |
| P1286 | ECM-913C | Throttle unit | Faulty signal |
| P1287 | ECM-913C | Throttle unit | Faulty signal |
| P1293 | ECM-914F | Throttle unit | Faulty signal |
| P1480 | ECM-6100 | Engine cooling fan (FC) control module | Faulty signal |
| P1481 | ECM-6110 | Engine cooling fan (FC) relay | Signal too low. Intermittent fault |
| P1481 | ECM-6110 | Engine cooling fan (FC) relay | Signal too low. Permanent fault |
| P1482 | ECM-6110 | Engine cooling fan (FC) relay | Signal too high. Intermittent fault |
| P1482 | ECM-6110 | Engine cooling fan (FC) relay | Signal too high. Permanent fault |
| P1526 | ECM-980A | Engine control module (ECM). | Intermittent fault Internal fault |
| P1526 | ECM-980A | Engine control module (ECM). | Permanent fault Internal fault |
| P1554 | ECM-801A | System relay | Faulty signal or signal missing |
| P1555 | ECM-801A | System relay | Faulty signal or signal |
| P1638 | ECM-715D | Engine control module (ECM) missing, high temperature | undefined |
| P1651 | ECM-981A | Engine control module (ECM). | Intermittent fault Internal fault |
| P1651 | ECM-981A | Engine control module (ECM). | Permanent fault Internal fault |
| P1652 | ECM-982A | Engine control module (ECM). | Intermittent fault Internal fault |
| P1652 | ECM-982A | Engine control module (ECM). | Permanent fault Internal fault |
| P1680 | ECM-720A | Immobilizer communication | Signal missing. Intermittent fault |
| P1680 | ECM-720A | Immobilizer communication | Signal missing. Permanent fault |
| P1721 | ECM-6220 | Control module cooling fan | Signal too high |
| P1722 | ECM-6220 | Control module cooling fan | Signal too low |
| P1723 | ECM-6220 | Control module cooling fan | Signal missing |
| P2088 | ECM-6400 | Intake camshaft reset valve | Signal too low or signal missing |
| P2089 | ECM-6400 | Intake camshaft reset valve | Signal too low or signal missing |
| P2090 | ECM-6410 | Exhaust camshaft reset valve | Signal too low or signal missing |
| P2091 | ECM-6410 | Exhaust camshaft reset valve | Signal too low or signal missing |
| P2101 | ECM-9100 | Engine control module (ECM) | Faulty signal |
| P2108 | ECM-919A | Engine control module (ECM) | Faulty signal |
| P2109 | ECM-918A | Engine control module (ECM). Internal fault | Intermittent fault |
| P2109 | ECM-918A | Engine control module (ECM). | Permanent fault Internal fault |
| P2111 | ECM-91B7 | Throttle unit | Faulty signal |
| P2112 | ECM-91C7 | Throttle unit | Faulty signal |
| P2119 | ECM-9117 | Throttle unit | Faulty signal |
| P2121 | ECM-9540 | Accelerator pedal (AP) position sensor, digital signal | Faulty signal |
| P2122 | ECM-9530 | Accelerator pedal (AP) position | Signal too low sensor, digital signal |
| P2123 | ECM-9530 | Accelerator pedal (AP) position | Signal too high sensor, digital signal |
| P2126 | ECM-9520 | Accelerator pedal (AP) position | Faulty signal sensor, analogy signal |
| P2127 | ECM-9520 | Accelerator pedal (AP) position | Signal too low sensor, analogy signal |
| P2128 | ECM-9520 | Accelerator pedal (AP) position | Signal too high sensor, analogy signal |
| P2131 | ECM-9400 | Brake pedal sensor | Faulty signal |
| P2135 | ECM-903C | Throttle position (TP) sensor | Faulty signal |
| P2177 | ECM-261A | Long-term fuel trim | Upper limit |
| P2178 | ECM-261A | Long-term fuel trim | Lower limit |
| P2179 | ECM-271A | Long-term fuel trim, bank 2 | Upper limit |
| P2180 | ECM-271A | Long-term fuel trim, bank 2 | Lower limit |
| P2187 | ECM-262A | Long-term fuel trim | Upper limit |
| P2188 | ECM-262A | Long-term fuel trim | Lower limit |
| P2189 | ECM-272A | Long-term fuel trim, bank 2 | Upper limit |
| P2190 | ECM-272A | Long-term fuel trim, bank 2 | Lower limit |
| P2191 | ECM-260A | Long-term fuel trim | Upper limit |
| P2192 | ECM-260A | Long-term fuel trim | Lower limit |
| P0101 | ECM-130A | Mass air flow (MAF) sensor | Faulty signal |
| P0102 | ECM-1300 | Mass air flow (MAF) sensor | Signal too low |
| P0103 | ECM-1300 | Mass air flow (MAF) sensor | Signal too high |
| P0106 | ECM-140A | Manifold absolute pressure (MAP) sensor | Faulty signal |
| P0107 | ECM-1400 | Manifold absolute pressure (MAP) sensor | Signal too low |
| P0108 | ECM-1400 | Manifold absolute pressure | Signal too high |
| P0111 | ECM-120A | Intake air temperature (IAT) sensor inlet | Faulty signal |
| P0112 | ECM-1200 | Intake air temperature (IAT) sensor inlet | Signal too low |
| P0113 | ECM-1200 | Intake air temperature (IAT) sensor inlet | Signal too high |
| P0116 | ECM-200A | Engine coolant temperature (ECT) sensor | Faulty signal |
| P0117 | ECM-2000 | Engine coolant temperature (ECT) sensor | Signal too low |
| P0118 | ECM-2000 | Engine coolant temperature (ECT) sensor | Signal too high |
| P0120 | ECM-950F | Accelerator pedal (AP) position sensor | Faulty signal |
| P0121 | ECM-951F | Accelerator pedal (AP) position sensor, internal fault | Faulty signal |
| P0122 | ECM-9530 | Accelerator pedal (AP) position sensor | Signal too low |
| P0123 | ECM-9530 | Accelerator pedal (AP) position sensor | Signal too high |
| P0125 | ECM-200F | Engine coolant temperature (ECT) sensor | Faulty signal |
| P0130 | ECM-2120 | Front heated oxygen sensor (HO2S), guide element | Signal too low |
| P0130 | ECM-2120 | Front heated oxygen sensor (HO2S), guide element | Signal too high |
| P0131 | ECM-2100 | Front heated oxygen sensor (HO2S) | Current too low |
| P0132 | ECM-2100 | Front heated oxygen sensor (HO2S) | Current too high |
| P0133 | ECM-210A | Front heated oxygen sensor (HO2S) | Faulty signal |
| P0135 | ECM-2110 | Front heated oxygen sensor (HO2S), preheating | Signal too low |
| P0135 | ECM-2110 | Front heated oxygen sensor (HO2S), preheating | Signal too high |
| P0136 | ECM-220A | Rear heated oxygen sensor (HO2S) | Faulty signal |
| P0137 | ECM-2200 | Rear heated oxygen sensor (HO2S) | Signal too low |
| P0138 | ECM-2200 | Rear heated oxygen sensor (HO2S) | Signal too high |
| P0141 | ECM-2210 | Rear heated oxygen sensor (HO2S), preheating | Signal too low |
| P0141 | ECM-2210 | Rear heated oxygen sensor (HO2S), preheating | Signal too high |
| P0171 | ECM-250A | Long-term fuel trim | Lower limit |
| P0172 | ECM-250A | Long-term fuel trim | Upper limit |
| P0201 | ECM-2300 | Injector, cylinder 1 | Faulty signal |
| P0202 | ECM-2310 | Injector, cylinder 2 | Faulty signal |
| P0203 | ECM-2320 | Injector, cylinder 3 | Faulty signal |
| P0204 | ECM-2330 | Injector, cylinder 4 | Faulty signal |
| P0205 | ECM-2340 | Injector, cylinder 5 | Faulty signal |
| P0220 | ECM-9150 | Throttle unit, internal fault | Faulty signal |
| P0221 | ECM-914F | Throttle unit, internal fault | Faulty signal |
| P0222 | ECM-9520 | Accelerator pedal (AP) position sensor | Signal too low |
| P0222 | ECM-9520 | Accelerator pedal (AP) position sensor | Signal missing |
| P0223 | ECM-9520 | Accelerator pedal (AP) position sensor | Signal too high |
| P0223 | ECM-9520 | Accelerator pedal (AP) position sensor | Faulty signal |
| P0225 | ECM-9160 | Throttle unit, internal fault | Faulty signal |
| P0227 | ECM-9540 | Power supply, 5 V | Signal too low |
| P0228 | ECM-9540 | Power supply, 5 V | Signal too high |
| P0230 | ECM-2400 | Fuel pump (FP) relay | Signal too low |
| P0230 | ECM-2400 | Fuel pump (FP) relay | Signal too high |
| P0301 | ECM-3502 | Misfiring | Cylinder 1 |
| P0302 | ECM-3502 | Misfiring | Cylinder 2 |
| P0303 | ECM-3502 | Misfiring | Cylinder 3 |
| P0304 | ECM-3502 | Misfiring | Cylinder 4 |
| P0305 | ECM-3502 | Misfiring | Cylinder 5 |
| P0326 | ECM-340A | Knock sensor (KS) | Too little roar |
| P0326 | ECM-340A | Knock sensor (KS) | Too much roar |
| P0327 | ECM-3400 | Knock sensor (KS) | Signal too low |
| P0328 | ECM-3400 | Knock sensor (KS) | Signal too high |
| P0335 | ECM-3100 | Engine speed (RPM) sensor | Faulty signal |
| P0339 | ECM-310A | Engine speed (RPM) sensor | Intermittent fault |
| P0340 | ECM-3000 | Camshaft sensor | Faulty signal |
| P0341 | ECM-300A | Camshaft sensor | Faulty signal |
| P0350 | ECM-3200 | Ignition coil | Faulty signal |
| P0351 | ECM-3300 | Ignition coil, cylinder 1 | Faulty signal |
| P0352 | ECM-3310 | Ignition coil, cylinder 2 | Faulty signal |
| P0353 | ECM-3320 | Ignition coil, cylinder 3 | Faulty signal |
| P0354 | ECM-3330 | Ignition coil, cylinder 4 | Faulty signal |
| P0355 | ECM-3340 | Ignition coil, cylinder 5 | Faulty signal |
| P0420 | ECM-4201 | Catalytic converter power | Power deterioration |
| P0440 | ECM-4047 | Canister purge (CP) valve/EVAP canister shut-off valve | Canister purge (CP) valve leakage |
| P0440 | ECM-4047 | Canister purge (CP) valve/EVAP canister shut-off valve | EVAP canister shut-off valve leakage |
| P0440 | ECM-4047 | Canister purge (CP) valve/EVAP canister shut-off valve | EVAP canister shut-off valve clogged |
| P0442 | ECM-4308 | Leak diagnostic | Minor leak |
| P0443 | ECM-4000 | Canister purge (CP) valve | Signal too low |
| P0443 | ECM-4000 | Canister purge (CP) valve | Signal too high |
| P0446 | ECM-4010 | EVAP canister shut-off valve | Faulty signal |
| P0451 | ECM-402A | Fuel tank pressure sensor | Faulty signal |
| P0452 | ECM-4020 | Fuel tank pressure sensor | Signal too low |
| P0452 | ECM-4020 | Fuel tank pressure sensor | Signal too low. Intermittent fault |
| P0453 | ECM-4020 | Fuel tank pressure sensor | Signal too high |
| P0453 | ECM-4020 | Fuel tank pressure sensor | Signal too high. Intermittent fault |
| P0455 | ECM-4308 | Leak diagnostic | Major leak |
| P0463 | ECM-4050 | Fuel level sensor | Faulty signal |
| P0480 | ECM-6110 | Engine cooling fan (FC) relay, low-speed | Signal too low |
| P0480 | ECM-6110 | Engine cooling fan (FC) relay, low-speed | Signal too high |
| P0481 | ECM-6120 | Engine cooling fan (FC) relay, high-speed | Signal too low |
| P0481 | ECM-6120 | Engine cooling fan (FC) relay, high-speed | Signal too high |
| P0500 | ECM-510D | Speed signal | Faulty signal |
| P0505 | ECM-6207 | Air assisted control valve (AACV) | Flow too low |
| P0506 | ECM-620A | Idle | Too little response |
| P0507 | ECM-620A | Idle | Too much response |
| P0531 | ECM-500A | A/C pressure sensor | Faulty signal |
| P0532 | ECM-5000 | A/C pressure sensor | Signal too low |
| P0533 | ECM-5000 | A/C pressure sensor | Signal too high |
| P0560 | ECM-820A | System relay | Faulty signal |
| P0562 | ECM-8010 | Battery voltage, charging | Signal too low |
| P0563 | ECM-8010 | Battery voltage, charging | Signal too high |
| P0571 | ECM-941F | Brake pedal sensor | Faulty signal |
| P0572 | ECM-9400 | Brake pedal sensor | Signal too low |
| P0600 | ECM-A00B | Communication, transmission control module (TCM) | Faulty signal |
| P0600 | ECM-A02B | Communication, anti-lock brake system module (ABS) | Faulty signal |
| P0600 | ECM-A03B | Communication, central electronic module (CEM) | Faulty signal |
| P0600 | ECM-E000 | Communication, CAN bus off | Faulty signal |
| P0600 | ECM-E003 | Communication, CAN bus | Faulty signal |
| P0603 | ECM-8000 | +30 supply to the control module | Open-circuit |
| P0608 | ECM-8400 | Power supply 5 V | Signal too high |
| P0608 | ECM-8400 | Power supply 5 V | Signal too high. Intermittent fault |
| P0645 | ECM-6000 | Air conditioning (A/C) relay | Signal too low |
| P0645 | ECM-6000 | Air conditioning (A/C) relay | Signal too low. Intermittent fault |
| P0645 | ECM-6000 | Air conditioning (A/C) relay | Signal too high |
| P0645 | ECM-6000 | Air conditioning (A/C) relay | Signal too high. Intermittent fault |
| P0805 | ECM-9300 | Clutch pedal sensor | Signal too low |
| P0805 | ECM-9300 | Clutch pedal sensor | Signal too high |
| P0806 | ECM-921F | Clutch pedal sensor | Faulty signal |
| P1111 | ECM-110A | Outer temperature sensor | Faulty signal |
| P1112 | ECM-1100 | Outer temperature sensor | Signal too low |
| P1112 | ECM-1100 | Outer temperature sensor | Signal too low. Intermittent fault |
| P1113 | ECM-1100 | Outer temperature sensor | Signal too high |
| P1113 | ECM-1100 | Outer temperature sensor | Signal too high. Intermittent fault |
| P1115 | ECM-100A | Engine control module (ECM), internal fault | Faulty signal |
| P1116 | ECM-1000 | Engine control module (ECM), internal fault | Signal too low |
| P1116 | ECM-1000 | Engine control module (ECM), internal fault | Signal too low. Intermittent fault |
| P1117 | ECM-1000 | Engine control module (ECM), internal fault | Signal too high |
| P1117 | ECM-1000 | Engine control module (ECM), internal fault | Signal too high. Intermittent fault |
| P1118 | ECM-150A | Mass air flow (MAF) sensor | Upper limit |
| P1119 | ECM-150A | Mass air flow (MAF) sensor | Lower limit |
| P1169 | ECM-D00E | Front heated oxygen sensor (HO2S) | Faulty signal |
| P1336 | ECM-5200 | Starter motor | Signal too low |
| P1336 | ECM-5200 | Starter motor | Signal too high |
| P1513 | ECM-9400 | Brake pedal sensor | Faulty signal |
| P1525 | ECM-91DF | Stop lamp switch | Faulty signal |
| P1528 | ECM-91CF | Engine control module (ECM), internal fault | Faulty signal |
| P1560 | ECM-9200 | Cruise control | Signal too high |
| P1560 | ECM-9200 | Cruise control | Faulty signal |
| P1562 | ECM-9200 | Cruise control | Signal too high |
| P1562 | ECM-9200 | Cruise control | Faulty signal |
| P1600 | ECM-9190 | Throttle unit, internal fault | Faulty signal |
| P1601 | ECM-91F0 | Throttle unit, internal fault | Faulty signal |
| P1602 | ECM-91B7 | Throttle unit, internal fault | Faulty signal |
| P1603 | ECM-91A7 | Throttle unit, internal fault | Faulty signal |
| P1604 | ECM-910E | Throttle unit, internal fault | Faulty signal |
| P1605 | ECM-911A | Throttle unit communication | Faulty signal |
| P1606 | ECM-912A | Engine control module (ECM) communication | Faulty signal |
| P1607 | ECM-91E0 | Battery voltage | Faulty signal |
| P1608 | ECM-903F | Throttle unit, internal fault | Faulty signal |
| P1610 | ECM-903F | Throttle unit, internal fault | Faulty signal |
| P1611 | ECM-902A | Throttle unit communication | Faulty signal |
| P1612 | ECM-902B | Throttle unit communication | Faulty signal |
| P1613 | ECM-902B | Throttle unit communication | Faulty signal |
| P1614 | ECM-913F | Engine control module (ECM), internal fault | Faulty signal |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 1 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 2 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 3 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 4 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 5 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 6 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 7 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 8 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 9 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 10 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 11 |
| P1615 | ECM-900E | Engine control module (ECM), internal fault | Faulty signal 12 |
| P1618 | ECM-530D | Diagnostic trouble code (DTC) in the transmission control module (TCM) | Faulty signal |
| P1619 | ECM-531D | Diagnostic trouble code (DTC) in the combined instrument panel | Faulty signal |
| P1620 | ECM-532D | MIL requested by the throttle unit | Faulty signal |
| P1621 | ECM-710A | CAN communication | Faulty signal |
| P1622 | ECM-7110 | Engine control module (ECM), internal fault | Faulty signal |
| P1623 | ECM-7120 | Engine control module (ECM), internal fault | Faulty signal |
| P1628 | ECM-901A | Engine control module (ECM) communication | Faulty signal |
| P1629 | ECM-901A | Engine control module (ECM) communication | Faulty signal |
| P1635 | ECM-7140 | Engine control module (ECM), internal fault | Signal too low |
| P1635 | ECM-7140 | Engine control module (ECM), internal fault | Signal too low. Intermittent fault |
| P1636 | ECM-7140 | Engine control module (ECM), internal fault | Signal too high |
| P1636 | ECM-7140 | Engine control module (ECM), internal fault | Signal too high. Intermittent fault |
| P1637 | ECM-715D | Engine control module (ECM) | High temperature |
| P1638 | ECM-716D | Engine control module (ECM) | High temperature |
| P1651 | ECM-980F | Manifold absolute pressure (MAP) sensor | Faulty signal 12 |
| P1657 | ECM-6300 | Electronic throttle system (ETS) warning lamp | Signal too low |
| P1658 | ECM-6310 | Electronic throttle system (ETS) warning lamp | Signal too high |
| P1660 | ECM-922A | Cruise control | Faulty signal |
| P1661 | ECM-922A | Cruise control | Faulty signal |
| P1662 | ECM-922A | Cruise control | Faulty signal |
| P1663 | ECM-922A | Cruise control | Faulty signal |
| P1670 | ECM-720A | Immobilizer communication | Faulty VIN code |
| P1670 | ECM-720A | Immobilizer communication | Faulty communication |
| P1670 | ECM-720A | Immobilizer communication | No communication |
| P1671 | ECM-6400 | Camshaft reset valve | Signal too low |
| P1671 | ECM-6400 | Camshaft reset valve | Signal too high |
| P1672 | ECM-640A | Camshaft reset valve | Faulty signal |
