Volvo V70 Transmission Drain and Fill Tutorial (2001+)
volvo_v70_drain_fill_transmission_fluidSave Money – Get the Toyota Transmission Fluid
I did all the research I could do on the topic and made the decision to go with the Toyota Type IV ATF going with the simplified drain and fill method. We have a local dealership here in town with plenty of the fluid readily available and since there is not too much money coming into the pockets to our friends from Toyota I thought that would give them my business; the parts guy was actually surprised that I was not inquiring about another recall item.
My father in law helped me in the process and it surely made things easier.
I bought 14 qts of ATF for $75 and a long neck funnel for $2.99 from Auto Zone (make sure you get one with a very small opening).
… See 2001 V70 2.4T ATF simple Drain and Fill… for the entire procedure …
In conclusion, the drain and fill method was very easy and straight forward. I am very satisfied with the results and after returning 3 qts back to the dealership the whole process cost me $63. As mentioned before, the original fluid was by no means burnt or in any way in bad shape, but certainly discolored. Now that I have done the ATF replacement, I will keep a good eye on the fluid level and looking for any leaks in the future. The shifting of the gears is very smooth (did not have any issues prior) and I will do this again in about 50,000 miles.
Forum views 75840Forum replies 119
Date February 11, 2010
4 responses to “Volvo V70 Transmission Drain and Fill Tutorial (2001+)”
  1. […] fluid flush or drain and fill 2001+ (read about the trans flush […]
  2. […] have been flushing my ATF (as opposed to a Transmission Drain & Fill… in other words: where I disconnect the cooler hose and flush ATF) using the following […]
  3. Alex says:
    Nicely done. I’ve been doing this partial transmission fluid change for about 15 years on my 240s. Every summer I drain and fill. I figure this way, although my fluid is never brand new, it’s never worn out, either. I do it twice, to start, separated by a week or so, then once a year thereafter. Works like a charm.
  4. Amo says:
    What ATF volume should i use to fill up in my 2007 V70 2.4l Automatic, after draining it since i have noticed some leaks.
