XC90 Transmission Fluid Flush
XC90 Transmission Fluid Flushing
All 5 speed auto’s by A-W use JWS-3309 spec fluid. Switching it to Mobil1 synthetic will mess that transmission up. That said, Mobil-3309 would be an excellent choice in that case. Just check your owner’s manual to make sure of the fluid but as far as I know, besides those with the GM transmission, the A-W (Aisin-Warner’s) take the newer fluid. If you have a GM transmission and it calls for Dexron-III then yeah, the Mobil1 Synthetic ATF would be fine.
XC90 2004 TRANSMISSION FLUID FLUSH
Date March 17, 2009
