1998 V70R Turbo vacuum line – How to get it off?
How to Replace Vacuum Hoses that go to Turbo
“As far as getting that red coded vac line to the turbo off, the one below the compression bypass valve, I sprayed a lot of WD-40 on that fitting from below. Then, from above , kneeling on the engine, with some long, 45 degree needle nose pliers (long ones – 7″ or more; best $8 I have spent in a while) reached down and pulled the hose off pretty much with brute force.”
