1998 Volvo v70 xc – awd fuel pump issue?
XC70 fuel pump access instructions without removing the fuel tank.
3499473366 d848a7a22f m - 1998 Volvo v70 xc - awd fuel pump issue?
Problem – can’t figure out how to get the fuel lines and the wire connectors off the tank. The fuel lines (pretty rusty) seem to have some kind of push/slide lock, but the outer part of the fitting on the lines doesn’t seem to be separate or movable. The rubber hoses are on pretty tight.
One Reply to “1998 Volvo v70 xc – awd fuel pump issue?”
  1. I’ve taken the pump out, but when I pulled the fuel lines off the pump, the set of clips that hold the lines to the pump were bent and/or broken. Where do I get new clips so I can attach the lines back to the new pump?
