About Volvo Trouble Codes (DTC)
OBD II is a diagnostics system designed to meet statutory requirements. A standardized instrument for fault-tracing can be plugged in to the data link connECM-tor (DLC) (OBD II socket) to read diagnostic trouble codes (DTCs) and system parameters.
OBD II contains only emissions related diagnostic trouble codes (DTCs) and parameters. It cannot provide the comprehensive range of information available from the Volvo On-board diagnostics system. Volvo has its own diagnostic trouble code (DTC) designations that adhere to the in-house Volvo On-board Diagnostics protocol (called DII from model year 1999).
Table explanations
The table below is a conversion table between standardised diagnostic trouble codes (DTCs) (SAE/ISO) and the equivalent Volvo diagnostic trouble codes (DTCs) (DII). SAE/ISO diagnostic trouble code (DTC): Standardized diagnostic trouble code (DTC) according to SAE J2012/ISO 15031-6. The diagnostic trouble code (DTC) can be read off on vehicles with standardised on-board diagnostic systems for emissions related faults, certified in accordance with OBD II.
Please help us add to this by posting your additions to this topic.
Volvo Codes Table 1999+
SAE/ISO | Volvo DII | DTC designation | Fault type |
P0010 | ECM-6400 | Intake camshaft reset valve | Signal too low or signal missing |
P0011 | ECM-640A | Camshaft control, intake | Faulty signal |
P0013 | ECM-6410 | Exhaust camshaft reset valve | Signal too low or signal missing |
P0014 | ECM-641A | Camshaft control, exhaust | Faulty signal |
P0016 | ECM-643A | Camshaft position, intake | Signal too low |
P0016 | ECM-643A | Camshaft position, intake | Signal too high |
P0017 | ECM-644A | Camshaft position, exhaust | Signal too low |
P0017 | ECM-644A | Camshaft position, exhaust | Signal too high |
P0030 | ECM-2810 | Front heated oxygen sensor (HO2S), preheating | Signal missing. Intermittent fault |
P0030 | ECM-2810 | Front heated oxygen sensor (HO2S), preheating | Signal missing. Permanent fault |
P0031 | ECM-2810 | Front heated oxygen sensor (HO2S), preheating | Signal too low. Intermittent fault |
P0031 | ECM-2810 | Front heated oxygen sensor (HO2S), preheating | Signal too low. Permanent fault |
P0032 | ECM-2810 | Front heated oxygen sensor (HO2S), Signal too high. preheating | Intermittent fault |
P0032 ECM-2810 Front heated oxygen sensor (HO2S), preheating Signal too high. Permanent fault P0036 ECM-2A20 Heated oxygen sensor (HO2S) bank Signal missing 1, preheating P0037 ECM-2A20 Heated oxygen sensor (HO2S) bank Signal too low 1, preheating P0038 ECM-2A20 Heated oxygen sensor (HO2S) bank Signal too high 1, preheating P0040 ECM-280C Front heated oxygen sensors (HO2S) Faulty signal P0050 ECM-2910 Front heated oxygen sensor (HO2S) Signal missing preheating, bank 2 P0051 ECM-2910 Front heated oxygen sensor (HO2S) Signal too low preheating, bank 2 P0052 ECM-2910 Front heated oxygen sensor (HO2S) Signal too high preheating, bank 2 P0056 ECM-2B20 Heated oxygen sensor (HO2S) bank Signal missing 2, preheating P0057 ECM-2B20 Heated oxygen sensor (HO2S) bank Signal too low 2, preheating P0058 ECM-2B20 Heated oxygen sensor (HO2S) bank Signal too high 2, preheating P0071 ECM-1100 Outer temperature sensor Faulty signal
P0072 ECM-1100 Outer temperature sensor Signal too low P0073 ECM-1100 Outer temperature sensor Signal too high P0101 ECM-130A Intake air leakage Faulty signal P0102 ECM-1300 Mass air flow (MAF) sensor Flow too low. Intermittent fault P0102 ECM-1300 Mass air flow (MAF) sensor Flow too low. Permanent fault P0103 ECM-1300 Mass air flow (MAF) sensor Flow too high. Intermittent fault P0103 ECM-1300 Mass air flow (MAF) sensor Flow too high. Permanent fault P0105 ECM-1000 Control module Faulty signal P0107 ECM-1000 Control module Signal too high / signal too low. Intermittent fault P0107 ECM-1000 Control module Signal too high / signal too low. Permanent fault P0108 ECM-1000 Control module Signal too high / signal too low. Intermittent fault P0108 ECM-1000 Control module Signal too high / signal too low. Permanent fault P0111 ECM-1200 Intake air temperature (IAT) inlet Faulty signal P0112 ECM-1200 Intake air temperature (IAT) inlet Signal too high. Intermittent fault P0112 ECM-1200 Intake air temperature (IAT) inlet Signal too high. Permanent fault P0113 ECM-1200 Intake air temperature (IAT) inlet Signal too low. Intermittent fault
P0113 ECM-1200 Intake air temperature (IAT) inlet Signal too low. Permanent fault P0121 ECM-9150 Throttle unit, potentiometer 1 Faulty signal P0122 ECM-9150 Throttle unit, potentiometer 1 Signal too low P0123 ECM-9150 Throttle unit, potentiometer 1 Signal too high P0128 ECM-201A Thermostat Faulty signal P0130 ECM-280A Front heated oxygen sensor (HO2S), faulty signal Signal missing. Intermittent fault P0130 ECM-280A Front heated oxygen sensor (HO2S), faulty signal Signal missing. Permanent fault P0132 ECM-280A Front heated oxygen sensor (HO2S), Signal too high. faulty signal Intermittent fault P0132 ECM-280A Front heated oxygen sensor (HO2S), faulty signal Signal too high. Permanent fault P0133 ECM-280A Front heated oxygen sensor (HO2S), faulty signal Signal too low. Intermittent fault P0133 ECM-280A Front heated oxygen sensor (HO2S), faulty signal Signal too low. Permanent fault P0134 ECM-280A Front heated oxygen sensor (HO2S) Faulty signal. Intermittent fault P0134 ECM-280A Front heated oxygen sensor (HO2S) Faulty signal. Permanent fault P0135 ECM-290A Front heated oxygen sensor (HO2S), preheating Faulty signal. Intermittent fault P0135 ECM-290A Front heated oxygen sensor (HO2S), preheating Faulty signal. Permanent fault P0136 ECM-2A0A Rear heated oxygen sensor (HO2S) Signal missing. Intermittent fault P0136 ECM-2A0A Rear heated oxygen sensor (HO2S) Signal missing. Permanent fault P0137 ECM-2A0A Rear heated oxygen sensor (HO2S) P0137 ECM-2A0A Rear heated oxygen sensor (HO2S) P0138 ECM-2A0A Rear heated oxygen sensor (HO2S) Signal too high. Intermittent fault P0138 ECM-2A0A Rear heated oxygen sensor (HO2S) Signal too high. Permanent fault P0140 ECM-2A1A Rear heated oxygen sensor (HO2S) Signal too low aging P0140 ECM-2A1A Rear heated oxygen sensor (HO2S) Signal too high aging P0140 ECM-2A1A Rear heated oxygen sensor (HO2S) Signal missing aging P0141 ECM-2A2A Rear heated oxygen sensor (HO2S) Faulty signal preheating
P0150 ECM-290A Front heated oxygen sensor (HO2S), bank 2 Signal missing. Intermittent fault P0150 ECM-290A Front heated oxygen sensor (HO2S), bank 2 Signal missing. Permanent fault P0152 ECM-290A Front heated oxygen sensor (HO2S), Signal too high bank 2 P0153 ECM-290A Front heated oxygen sensor (HO2S), bank 2 Signal too low. Intermittent fault P0153 ECM-290A Front heated oxygen sensor (HO2S), bank 2 Signal too low. Permanent fault P0154 ECM-290A Front heated oxygen sensor (HO2S), bank 2 Faulty signal. Intermittent fault P0154 ECM-290A Front heated oxygen sensor (HO2S), bank 2 Faulty signal. Permanent fault P0155 ECM-2910 Front heated oxygen sensor (HO2S) Faulty signal. Intermittent preheating, bank 2 fault P0155 ECM-2910 Front heated oxygen sensor (HO2S) Faulty signal. Permanent preheating, bank 2 P0156 ECM-2B0A Rear heated oxygen sensor (HO2S) Signal missing. Intermittent bank 2 P0156 ECM-2B0A Rear heated oxygen sensor (HO2S) Signal missing. Permanent bank 2 P0157 ECM-2B0A Rear heated oxygen sensor (HO2S), bank 2 fault P0157 ECM-2B0A Rear heated oxygen sensor (HO2S), bank 2 P0158 ECM-2B0A Rear heated oxygen sensor (HO2S) Signal too high. bank 2 Intermittent fault P0158 ECM-2B0A Rear heated oxygen sensor (HO2S) Signal too high. Permanent bank 2 fault P0160 ECM-2B1A Rear heated oxygen sensor (HO2S) Signal too low ageing, bank 2 P0160 ECM-2B1A Rear heated oxygen sensor (HO2S) Signal too high ageing, bank 2 P0160 ECM-2B1A Rear heated oxygen sensor (HO2S) Signal missing ageing, bank 2 P0161 ECM-2B2A Rear heated oxygen sensor (HO2S) Faulty signal preheating, bank 2 P1729 ECM-9170 Throttle unit Faulty signal P0201 ECM-2310 InjECM-tor 1 Signal missing. Intermittent fault P0201 ECM-2310 InjECM-tor 1 Signal missing. Permanent fault P0202 ECM-2320 InjECM-tor 2 Signal missing. Intermittent fault P0202 ECM-2320 InjECM-tor 2 Signal missing. Permanent fault P0203 ECM-2330 InjECM-tor 3 Signal missing. Intermittent fault
P0203 ECM-2330 InjECM-tor 3 Signal missing. Permanent fault P0204 ECM-2340 InjECM-tor 4 Signal missing. Intermittent fault P0204 ECM-2340 InjECM-tor 4 Signal missing. fault P0205 ECM-2350 InjECM-tor 5 Signal missing. Intermittent fault P0205 ECM-2350 InjECM-tor 5 Signal missing. Permanent fault P0206 ECM-2360 InjECM-tor 6 Signal missing. Intermittent fault P0206 ECM-2360 InjECM-tor 6 Signal missing. Permanent fault P0221 ECM-9160 Throttle unit, potentiometer 2 Faulty signal P0222 ECM-9160 Throttle unit, potentiometer 2 Signal too low P0223 ECM-9160 Throttle unit, potentiometer 2 Signal too high P0230 ECM-2400 Fuel pump (FP) relay Signal missing. Intermittent fault P0230 ECM-2400 Fuel pump (FP) relay Signal missing. Permanent fault P0231 ECM-2400 Fuel pump (FP) relay Signal too low. Intermittent fault P0231 ECM-2400 Fuel pump (FP) relay Signal too low. Permanent fault P0232 ECM-2400 Fuel pump (FP) relay Signal too high. Intermittent fault P0232 ECM-2400 Fuel pump (FP) relay Signal too high. Permanent fault P0234 ECM-6805 Turbocharger (TC) control valve Pressure too high boost pressure fault P0235 ECM-1600 Boost pressure sensor Faulty signal P0236 ECM-170F Atmospheric pressure sensor / Faulty signal boost pressure sensor range chECM-k P0237 ECM-1600 Boost pressure sensor Signal too low P0238 ECM-1600 Boost pressure sensor Signal too high P0243 ECM-6800 Turbocharger (TC) control valve Signal missing. Intermittent fault P0243 ECM-6800 Turbocharger (TC) control valve Signal missing. Permanent fault P0245 ECM-6800 Turbocharger (TC) control valve Signal too low. Intermittent fault P0245 ECM-6800 Turbocharger (TC) control valve Signal too low. Permanent fault P0246 ECM-6800 Turbocharger (TC) control valve Signal too high. Intermittent fault P0246 ECM-6800 Turbocharger (TC) control valve Signal too high. Permanent fault P0261 ECM-2310 InjECM-tor 1 Signal too low. Intermittent fault
P0261 | ECM-2310 | InjECM-tor 1 | Signal too low. Permanent fault |
P0262 | ECM-2310 | InjECM-tor 1 | Signal too high. Intermittent fault |
P0262 | ECM-2310 | InjECM-tor 1 | Signal too high. Permanent fault |
P0264 | ECM-2320 | InjECM-tor 2 | Signal too low. Intermittent fault |
P0264 | ECM-2320 | InjECM-tor 2 | Signal too low. Permanent fault |
P0265 | ECM-2320 | InjECM-tor 2 | Signal too high. Intermittent fault |
P0265 | ECM-2320 | InjECM-tor 2 | Signal too high. Permanent fault |
P0267 | ECM-2330 | InjECM-tor 3 | Signal too low. Intermittent fault |
P0267 | ECM-2330 | InjECM-tor 3 | Signal too low. Permanent fault |
P0268 | ECM-2330 | InjECM-tor 3 | Signal too high. Intermittent fault |
P0268 | ECM-2330 | InjECM-tor 3 | Signal too high. Permanent fault |
P0270 | ECM-2340 | InjECM-tor 4 | Signal too low. Intermittent fault |
P0270 | ECM-2340 | InjECM-tor 4 | Signal too low. Permanent fault |
P0271 | ECM-2340 | InjECM-tor 4 | Signal too high. Intermittent fault |
P0271 | ECM-2340 | InjECM-tor 4 | Signal too high. Permanent fault |
P0273 | ECM-2350 | InjECM-tor 5 | Signal too low. Intermittent fault |
P0273 | ECM-2350 | InjECM-tor 5 | Signal too low. Permanent fault |
P0274 | ECM-2350 | InjECM-tor 5 | Signal too high. Intermittent fault |
P0274 | ECM-2350 | InjECM-tor 5 | Signal too high. Permanent fault |
P0276 | ECM-2360 | InjECM-tor 6 | Signal too low. Intermittent fault |
P0276 | ECM-2360 | InjECM-tor 6 | Signal too low. Permanent fault |
P0277 | ECM-2360 | InjECM-tor 6 | Signal too high. Intermittent fault |
P0277 | ECM-2360 | InjECM-tor 6 | Signal too high. Permanent fault |
P0299 | ECM-6806 | Turbocharger (TC) control valve | Pressure too low flow fault |
P0300 | ECM-3503 | Misfire, at least one cylinder | Emissions impact / catalytic converter damage |
P0301 | ECM-3513 | Misfire cylinder 1 | Emissions impact / catalytic converter damage |
P0302 | ECM-3523 | Misfire cylinder 2 | Emissions impact / catalytic converter damage |
P0303 | ECM-3533 | Misfire cylinder 3 | Emissions impact / catalytic converter damage |
P0304 | ECM-3543 | Misfire cylinder 4 | Emissions impact / catalytic converter damage |
P0305 | ECM-3553 | Misfire cylinder 5 | Emissions impact / catalytic converter damage |
P0306 | ECM-3563 | Misfire cylinder 6 | Emissions impact / catalytic converter damage |
P0324 | ECM-3400 | Knock sensor (KS), test pulse | Signal too high / signal too low. Intermittent fault |
P0324 | ECM-3400 | Knock sensor (KS), test pulse | Signal too high / signal too low. Permanent fault |
P0324 | ECM-34E0 | Knock sensor (KS), offset | Signal too high / signal too low. Intermittent fault |
P0324 | ECM-34E0 | Knock sensor (KS), offset | Signal too high / signal too low. Permanent fault |
P0324 | ECM-34F0 | Knock sensor (KS), test pulse | Signal too high / signal too low. Intermittent fault |
P0324 | ECM-34F0 | Knock sensor (KS), test pulse | Signal too high / signal too low. Permanent fault |
P0327 | ECM-3410 | Knock sensor (KS), front | Signal too low. Intermittent fault |
P0327 | ECM-3410 | Knock sensor (KS), front | Signal too low. Permanent fault |
P0328 | ECM-3410 | Knock sensor (KS), front | Signal too high. Intermittent fault |
P0328 | ECM-3410 | Knock sensor (KS), front | Signal too high. Permanent fault |
P0332 | ECM-3420 | Knock sensor (KS), rear | Signal too low. Intermittent fault |
P0332 | ECM-3420 | Knock sensor (KS), rear | Signal too low. Permanent fault |
P0333 | ECM-3420 | Knock sensor (KS), rear | Signal too high. Intermittent fault |
P0333 | ECM-3420 | Knock sensor (KS), rear | Signal too high. Permanent fault |
P0335 | ECM-5200 | Engine speed (RPM) sensor | Signal missing |
P0336 | ECM-5200 | Engine speed (RPM) sensor | Faulty signal |
P0337 | ECM-5200 | Engine speed (RPM) sensor | Signal too low |
P0338 | ECM-5200 | Engine speed (RPM) sensor | Signal too high |
P0340 | ECM-3000 | Camshaft position (CMP) sensor, intake | Faulty signal or signal missing |
P0342 | ECM-3000 | Camshaft position (CMP) sensor | Signal too low. Intermittent intake fault |
P0342 | ECM-3000 | Camshaft position (CMP) sensor | Signal too low. Permanent intake fault |
P0343 | ECM-3000 | Camshaft position (CMP) sensor | Signal too high. intake Intermittent fault |
P0343 | ECM-3000 | Camshaft position (CMP) sensor | Signal too high. Permanent intake fault |
P0344 | ECM-3000 | Camshaft position (CMP) sensor | Faulty signal or signal intake missing |
P0345 | ECM-3010 | Camshaft position (CMP) sensor | Faulty signal or signal exhaust missing |
P0347 | ECM-3010 | Camshaft position (CMP) sensor | Signal too low exhaust |
P0348 | ECM-3010 | Camshaft position (CMP) sensor | Signal too high exhaust |
P0349 | ECM-3010 | Camshaft position (CMP) sensor | Faulty signal or signal exhaust missing |
P0351 | ECM-3300 | Ignition coil cylinder 1, signal | Signal missing. Intermittent fault |
P0351 | ECM-3300 | Ignition coil cylinder 1, signal | Signal missing. Permanent fault |
P0352 | ECM-3310 | Ignition coil cylinder 2, signal | Signal missing. Intermittent fault |
P0352 | ECM-3310 | Ignition coil cylinder 2, signal | Signal missing. Permanent fault |
P0353 | ECM-3320 | Ignition coil cylinder 3, signal | Signal missing. Intermittent fault |
P0353 | ECM-3320 | Ignition coil cylinder 3, signal | Signal missing. Permanent fault |
P0354 | ECM-3330 | Ignition coil cylinder 4, signal | Signal missing. Intermittent fault |
P0354 | ECM-3330 | Ignition coil cylinder 4, signal | Signal missing. Permanent fault |
P0355 | ECM-3340 | Ignition coil cylinder 5, signal | Signal missing. Intermittent fault |
P0355 | ECM-3340 | Ignition coil cylinder 5, signal | Signal missing. Permanent fault |
P0420 | ECM-4801 | Three?way catalytic converter (TWC) Intermittent fault efficiency, bank 1 | |
P0420 | ECM-4801 | Three?way catalytic converter (TWC) Permanent fault efficiency, bank 1 | |
P0430 | ECM-4901 | Three?way catalytic converter (TWC) Intermittent fault efficiency, bank 2 | |
P0430 | ECM-4901 | Three?way catalytic converter (TWC) Permanent fault efficiency, bank 2 | |
P0443 | ECM-4000 | Evaporative emission system (EVAP) Signal missing. Intermittent valve | fault |
P0443 | ECM-4000 | Evaporative emission system (EVAP) Signal missing. Permanent valve | fault |
P0444 | ECM-4000 | Evaporative emission system (EVAP) Signal too high. valve | Intermittent fault |
P0444 | ECM-4000 | Evaporative emission system (EVAP) Signal too high. Permanent valve | fault |
P0445 | ECM-4000 | Evaporative emission system (EVAP) Signal too low. Intermittent valve | fault |
P0445 | ECM-4000 | Evaporative emission system (EVAP) Signal too low. Permanent valve | fault |
P0446 | ECM-4010 | Leak diagnostic unit, valve | Signal too high |
P0447 | ECM-4010 | Leak diagnostic unit, valve | Signal missing |
P0448 | ECM-4010 | Leak diagnostic unit, valve | Signal too low |
P0455 | ECM-400C | Fuel tank system, leakage | |
P0456 | ECM-400C | Fuel tank system, leakage | |
P0457 | ECM-4338 | Fuel tank filler cap missing | |
P0460 | ECM-405C | Fuel level sensor | |
P0461 | ECM-4050 | Fuel level sensor | Faulty signal |
P0462 | ECM-4050 | Fuel level sensor | Signal too low |
P0463 | ECM-4050 | Fuel level sensor | Signal too high |
P0464 | ECM-4050 | Fuel level sensor | Signal missing |
P0480 | ECM-6110 | Engine cooling fan (FC) relay | Signal missing. Intermittent fault |
P0480 | ECM-6110 | Engine cooling fan (FC) relay | Signal missing. Permanent fault |
P0483 | ECM-6100 | Engine cooling fan (FC) control | Faulty signal module |
P0484 | ECM-6100 | Engine cooling fan (FC) control | Faulty signal module |
P0485 | ECM-6100 | Engine cooling fan (FC) control | Faulty signal module |
P0496 | ECM-4007 | Evaporative emission system (EVAP) Signal too high | |
P0497 | ECM-4007 | Evaporative emission system (EVAP) Signal too low | |
P0500 | ECM-510F | Speed signal | |
P0506 | ECM-990A | Idle air control (IAC) | Faulty signal |
P0507 | ECM-990A | Idle air control (IAC) | Faulty signal |
P0530 | ECM-5000 | A/C pressure sensor | Signal missing. Intermittent fault |
P0530 | ECM-5000 | A/C pressure sensor | Signal missing. Permanent fault |
P0532 | ECM-5000 | A/C pressure sensor | Signal too low. Intermittent fault |
P0532 | ECM-5000 | A/C pressure sensor | Signal too low. Permanent fault |
P0533 | ECM-5000 | A/C pressure sensor | Signal too high. Intermittent fault |
P0533 | ECM-5000 | A/C pressure sensor | Signal too high. Permanent fault |
P0560 | ECM-8010 | Battery voltage | Faulty signal |
P0562 | ECM-8010 | Battery voltage | Signal too low |
P0563 | ECM-8010 | Battery voltage | Signal too high |
P0564 | ECM-928C | Control module, communication fault | Faulty signal |
P0571 | ECM-9400 | Brake pedal sensor | Signal missing |
P0573 | ECM-9400 | Brake pedal sensor | Signal too high |
P0579 | ECM-928C | Control module, communication | Faulty signal fault |
P0580 | ECM-928C | Control module, communication | Faulty signal fault |
P0581 | ECM-928C | Control module, communication | Faulty signal fault |
P0602 | ECM-531D | Control module, internal fault | |
P0604 | ECM-9050 | RAM memory fault | Internal fault. Intermittent fault |
P0604 | ECM-9050 | RAM memory fault | Internal fault. Permanent fault |
P0605 | ECM-9060 | ROM memory fault | Internal fault. Intermittent fault |
P0605 | ECM-9060 | ROM memory fault | Internal fault. Permanent fault |
P0606 | ECM-9070 | Control module, internal fault | Intermittent fault |
P0606 | ECM-9070 | Control module, internal fault | Permanent fault |
P0607 | ECM-711A | Engine control module (ECM-), internal fault | Signal too high / signal too low. Intermittent fault |
P0607 | ECM-711A | Engine control module (ECM-), internal fault | Signal too high / signal too low. Permanent fault |
P0630 | ECM-720A | Immobilizer communication | Faulty signal. Intermittent fault |
P0630 | ECM-720A | Immobilizer communication | Faulty signal. Permanent fault |
P0638 | ECM-91A7 | Throttle unit | Faulty signal |
P0634 | ECM-716D | Engine control module (ECM-), high temperature | |
P0642 | ECM-8410 | Power supply 5 volts | Signal too low. Intermittent fault |
P0642 | ECM-8410 | Power supply 5 volts | Signal too low. Permanent fault |
P0643 | ECM-8410 | Power supply 5 volts | Signal too high. Intermittent fault |
P0643 | ECM-8410 | Power supply 5 volts | Signal too high. Permanent fault |
P0645 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal missing. Intermittent fault |
P0645 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal missing. Permanent fault |
P0646 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal too low. Intermittent fault |
P0646 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal too low. Permanent fault |
P0647 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal too high. Intermittent fault |
P0647 | ECM-6000 | Air conditioning (A/C) relay, signal | Signal too high. Permanent fault |
P0650 | ECM-6B00 | Malfunction indicator lamp (MIL) | Signal missing. Intermittent signal fault |
P0650 | ECM-6B00 | Malfunction indicator lamp (MIL) | Signal missing. Permanent signal fault |
P0650 | ECM-6B00 | Malfunction indicator lamp (MIL) | Signal too low. Intermittent signal fault |
P0650 | ECM-6B00 | Malfunction indicator lamp (MIL) | Signal too low. Permanent signal fault |
P0650 | ECM-6B00 | Malfunction indicator lamp (MIL) | Signal too high. signal Intermittent fault |
P0650 | ECM-6B00 | Malfunction indicator lamp (MIL) | Signal too high. Permanent signal fault |
P0668 | ECM-7180 | Temperature sensor control module Signal too high / signal too low. Intermittent fault | |
P0668 | ECM-7180 | Temperature sensor control module Signal too high / signal too low. Permanent fault | |
P0669 | ECM-7180 | Temperature sensor control module Signal too high / signal too low. Intermittent fault | |
P0669 | ECM-7180 | Temperature sensor control module Signal too high / signal too low. Permanent fault | |
P0700 | ECM-530D | Diagnostic trouble code (DTC) in another control module | |
P0727 | ECM-3100 | Engine speed (RPM) sensor | Signal missing. Intermittent fault |
P0727 | ECM-3100 | Engine speed (RPM) sensor | Signal missing. Permanent fault |
P0805 | ECM-9300 | Clutch pedal sensor | Faulty signal |
P0807 | ECM-9300 | Clutch pedal sensor | Signal too low |
P0808 | ECM-9300 | Clutch pedal sensor | Signal too high |
P0863 | ECM-530B | Control module communication | |
P1177 | ECM-268A | Long?term fuel trim | |
P1178 | ECM-268A | Long?term fuel trim | |
P1179 | ECM-268A | Long?term fuel trim Lower limit | |
P1187 | ECM-278A | Faulty signal | |
P1188 | ECM-278A | ||
P1189 | ECM-278A | ||
P1234 | ECM-6814 | Turbocharger (TC) control system | |
P1285 | ECM-913F | Throttle unit Signal too high | |
P1286 | ECM-913C | Throttle unit Faulty signal | |
P1287 | ECM-913C | Throttle unit Faulty signal | |
P1293 | ECM-914F | Throttle unit Faulty signal | |
P1480 | ECM-6100 | Engine cooling fan (FC) control Faulty signal | Faulty signal |
P1481 | ECM-6110 | Engine cooling fan (FC) relay | Signal too low. Intermittent fault |
P1481 | ECM-6110 | Engine cooling fan (FC) relay | Signal too low. Permanent fault |
P1482 | ECM-6110 | Engine cooling fan (FC) relay | Signal too high. Intermittent fault |
P1482 | ECM-6110 | Engine cooling fan (FC) relay | Signal too high. Permanent fault |
P1526 | ECM-980A | Engine control module (ECM-). | Intermittent fault Internal fault |
P1526 | ECM-980A | Engine control module (ECM-). | Permanent fault Internal fault |
P1554 | ECM-801A | System relay | Faulty signal or signal missing |
P1555 | ECM-801A | System relay | Faulty signal or signal |
P1638 | ECM-715D | Engine control module (ECM-), high temperature | |
P1651 | ECM-981A | Engine control module (ECM-). | Intermittent fault Internal fault |
P1651 | ECM-981A | Engine control module (ECM-). | Permanent fault Internal fault |
P1652 | ECM-982A | Engine control module (ECM-). | Intermittent fault Internal fault |
P1652 | ECM-982A | Engine control module (ECM-). | Permanent fault Internal fault |
P1680 | ECM-720A | Immobilizer communication | Signal missing. Intermittent fault |
P1680 | ECM-720A | Immobilizer communication | Signal missing. Permanent fault |
P1721 | ECM-6220 | Control module cooling fan | |
P1722 | ECM-6220 | Control module cooling fan Signal too high | |
P1723 | ECM-6220 | Control module cooling fan Signal too low | |
P2088 | ECM-6400 | Intake camshaft reset valve Signal missing | Signal too low or signal missing |
P2089 | ECM-6400 | Intake camshaft reset valve | Signal too low or signal missing |
P2090 | ECM-6410 | Exhaust camshaft reset valve | Signal too low or signal missing |
P2091 | ECM-6410 | Exhaust camshaft reset valve | Signal too low or signal missing |
P2101 | ECM-9100 | Engine control module (ECM-) | |
P2108 | ECM-919A | Engine control module (ECM-) Faulty signal | |
P2109 | ECM-918A | Engine control module (ECM-). Faulty signal | Intermittent fault |
P2109 | ECM-918A | Engine control module (ECM-). | Permanent fault Internal fault |
P2111 | ECM-91B7 | Throttle unit | |
P2112 | ECM-91C7 | Throttle unit Faulty signal | |
P2119 | ECM-9117 | Throttle unit Faulty signal | |
P2121 | ECM-9540 | Accelerator pedal (AP) position | Faulty signal, sensor, digital signal |
P2122 | ECM-9530 | Accelerator pedal (AP) position | Signal too low sensor, digital signal |
P2123 | ECM-9530 | Accelerator pedal (AP) position | Signal too high sensor, digital signal |
P2126 | ECM-9520 | Accelerator pedal (AP) position | Faulty signal sensor, analogy signal |
P2127 | ECM-9520 | Accelerator pedal (AP) position | Signal too low sensor, analogy signal |
P2128 | ECM-9520 | Accelerator pedal (AP) position | Signal too high sensor, analogy signal |
P2131 | ECM-9400 | Brake pedal sensor | Faulty signal |
P2135 | ECM-903C | Throttle position (TP) sensor | |
P2177 | ECM-261A | Long?term fuel trim | |
P2178 | ECM-261A | Long?term fuel trim Upper limit | Lower limit |
P2179 | ECM-271A | Long?term fuel trim, bank 2 | Upper limit |
P2180 | ECM-271A | Long?term fuel trim, bank 2 | Lower limit |
P2187 | ECM-262A | Long?term fuel trim | Upper limit |
P2188 | ECM-262A | Long?term fuel trim | Lower limit |
P2189 | ECM-272A | Long?term fuel trim, bank 2 | Upper limit |
P2190 | ECM-272A | Long?term fuel trim, bank 2 | Lower limit |
P2191 | ECM-260A | Long?term fuel trim | Upper limit |
P2192 | ECM-260A | Long?term fuel trim | Lower limit |
P2193 | ECM-270A | Long?term fuel trim, bank 2 | Upper limit |
P2194 | ECM-270A | Long?term fuel trim, bank 2 | Lower limit |
P2232 | ECM-2A0A | Rear heated oxygen sensor (HO2S) | Faulty signal. Intermittent fault |
P2232 | ECM-2A0A | Rear heated oxygen sensor (HO2S) | Faulty signal. Permanent fault |
P2235 | ECM-2B0A | Rear heated oxygen sensor bank 2 | fault |
P2300 | ECM-3300 | Ignition coil cylinder 1, signal | Signal too low. Intermittent fault |
P2300 | ECM-3300 | Ignition coil cylinder 1, signal | Signal too low. Permanent fault |
P2301 | ECM-3300 | Ignition coil cylinder 1, signal | Signal too high. Intermittent fault |
P2301 | ECM-3300 | Ignition coil cylinder 1, signal | Signal too high. Permanent fault |
P2303 | ECM-3310 | Ignition coil cylinder 2, signal | Signal too low. Intermittent fault |
P2303 | ECM-3310 | Ignition coil cylinder 2, signal | Signal too low. Permanent fault |
P2304 | ECM-3310 | Ignition coil cylinder 2, signal | Signal too high. Intermittent fault |
P2304 | ECM-3310 | Ignition coil cylinder 2, signal | Signal too high. Permanent fault |
P2306 | ECM-3320 | Ignition coil cylinder 3, signal | Signal too low. Intermittent fault |
P2306 | ECM-3320 | Ignition coil cylinder 3, signal | Signal too low. Permanent fault |
P2307 | ECM-3320 | Ignition coil cylinder 3, signal | Signal too high. Intermittent fault |
P2307 | ECM-3320 | Ignition coil cylinder 3, signal | Signal too high. Permanent fault |
P2309 | ECM-3330 | Ignition coil cylinder 4, signal | Signal too low. Intermittent fault |
P2309 | ECM-3330 | Ignition coil cylinder 4, signal | Signal too low. Permanent fault |
P2310 | ECM-3330 | Ignition coil cylinder 4, signal | Signal too high. Intermittent fault |
P2310 | ECM-3330 | Ignition coil cylinder 4, signal | Signal too high. Permanent fault |
P2312 | ECM-3340 | Ignition coil cylinder 5, signal | Signal too low. Intermittent fault |
P2312 | ECM-3340 | Ignition coil cylinder 5, signal | Signal too low. Permanent fault |
P2313 | ECM-3340 | Ignition coil cylinder 5, signal | Signal too high. Intermittent fault |
P2313 | ECM-3340 | Ignition coil cylinder 5, signal | Signal too high. Permanent fault |
P2400 | ECM-4024 | Leak diagnostic unit, pump | |
P2401 | ECM-4024 | Leak diagnostic unit, pump | Signal missing |
P2402 | ECM-4024 | Leak diagnostic unit, pump | Signal too low |
P2404 | ECM-431D | Leak diagnostic unit | Signal too high |
P2405 | ECM-431D | Leak diagnostic unit | Faulty signal |
P2406 | ECM-431D | Leak diagnostic unit | Signal too low |
P2407 | ECM-431D | Leak diagnostic unit | Signal too high |
U0001 | ECM-E000 | Control module, internal fault | Signal missing |
U0002 | ECM-E000 | Control module, internal fault | Faulty signal. Permanent fault |
U0073 | ECM-E003 | Control module, internal fault | Faulty signal. Intermittent fault |
U0073 | ECM-E003 | Control module, internal fault | Faulty signal. Permanent fault |
