S80 Bulb Failure Position Light
S80 Bulb Failure Position Light = "parking/tail" lights. Sometimes they burn out - or the connections corrode and resistance builds up at the bulb.
S80 Bulb Failure Position Indicator
It can be one of the “parking/tail” lights. Sometimes they burn out – other times the connections corrode and resistance builds up at the base of the bulb. Rarely the socket will crack causing a loose connection. Here’s how to change them out:
  1. Switch off the ignition.
  2. Open the hood.
  3. Press down the retaining catch with a screwdriver and pull out the lamp housing.
  4. Press the retaining spring downward and pull the connector out of the lamp housing.
  5. Turn the bulb holder counterclockwise and remove it.
  6. Remove the defective bulb from the holder by first pressing it in slightly and then turning it counterclockwise.
  7. Install a new bulb in the holder and reinsert
2001 S80 T6 “Bulb Failure Position Indicator”
Share this
One Reply to “S80 Bulb Failure Position Light”
  1. great advice, thanks!
    ps
    in my case, the bulb was not gone, it was just a contact, in fact i just smacked the tail lights and everything went back to normal.
    thanks again!!! an a happy new year
