2002 Volvo S80 Maintenance Schedule
2002 Volvo S80 Maintenance Schedule for timing belt interval, engine oil, fuel filter, air filter, fluids, tire pressure, serpentine belt, etc.
Service Operation Schedule of Services
2002 S80
miles x 1000 7.5 15 22.5 30 37.5 45 52.5 60 67.5 75 82.5 90 97.5 105 112.5 120 127.5 135 142.5 150
km x 1000 12 24 36 48 60 72 84 96 108 120 132 144 156 168 180 192 204 216 228 240
months 12 24 36 48 60 72 84 96 108 120 132 144 156 168 180 192 204 216 228 240
Engine
PCV, inspect, clean nipple and hoses (Turbo Models Only)
X
X
Engine oil and filter, replace
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Service Reminder Indicator (SRI), reset
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Fuel lines, check for damage/leaks
X
X
X
X
X
X
X
Fuel filter, replace
X
Exhaust system/ check for damage leaks
X
X
X
X
X
X
X
X
X
X
X
X
X
Air filter cartridge/ replace*
X
X
X
X
Spark plugs/ replace (All models except S40/V40)
X
X
Spark plugs/ replace (S40/V40 Only)
X
X
X
Coolant level, check / adjust
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Battery, check fluid level, charge, mounting**
X
X
X
X
X
X
X
X
X
X
Auxiliary drive belt, check
X
Auxiliary drive belt, replace
X
Timing belt & Tensioner, replace
X
* May be necessary to change more frequently when driving in dusty/dirty areas.** Check more frequently when driving in severe climates. For service intervals beyond 150,000 miles, consult your authorized Volvo retailer.
Steering, Front and Rear Suspension
Power steering fluid level, check/adjust
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Steering/front suspension, check
X
X
X
X
X
X
X
X
X
X
X
X
X
Rear suspension, check for wear
X
X
X
X
X
X
X
X
X
X
X
X
X
Transmission, Driveshaft and Differential
Automatic transmission fluid level, check/adjust*
X
X
X
X
X
Bevel gear, visual inspection†
X
X
X
X
X
X
X
X
X
X
Driveshaft joints, check for wear/play
X
X
X
X
X
X
X
X
X
X
X
X
X
Driveshaft, check boots
X
X
X
X
X
X
X
X
X
X
X
X
X
Propeller shaft, pilot bearing and universal joints, check
wear
X
X
X
X
X
X
X
X
X
X
X
X
X
AOC AWD Coupling, Oil, Filter and O-Rings Repl† †
X
X
Controls and Lighting
Exterior lighting controls, check
X
X
X
X
X
X
X
X
X
X
Washer fluid level, check/adjust
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
* Volvo recommends changing automatic transmission fluid at 52,500 miles/84,000 kilometers, only on vehicles used for towing † All-wheel drive models only. † † All-wheel drive S60 models only.
Body
Power antenna, clean/lubricate (S40 and C70 only)
X
X
X
X
X
X
X
X
X
X
Cabin air filter, replace*
X
X
X
X
X
X
X
X
X
X
Doors, hood, trunk, sunroof; lubricate hinges, latches, sliding parts
X
X
X
X
X
X
X
X
X
X
Brake System
Brake fluid level, check
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Brake fluid, replace**
X
X
X
X
Parking brake, check/adjust
X
X
X
X
X
X
X
X
X
X
Brake pads, check
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Brake hoses and lines, check for damage/leaks
X
X
X
X
X
Wheels and Tires
Tires, check pressure, wear and condition
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Tires, rotate
X
X
General
Check and replace parts or software, as required by Volvo Cars of North
America, that are covered under the terms of the Volvo New Car Warranty.
* Recommended to replace more often in heavy traffic or dirty/dusty areas. ** Recommended to replace every two years or
37,500 miles (if driven in mountainous areas or humid climates – every one year) at owner’s request.
