240DL 86 Instrument Cluster weirdness
You may be alarmed when the temp gauge on your 240 is heading to the danger zone. As a precaution, always immediately discontinue driving the car until you can pull off to a safe location and check your engine coolant levels. However, sometimes the situation continues to occur even though all of the cooling system components are in check. You also may notice the temperature gauge moving sporadically. This is a common issue with the 200 series and the culprit is a temperature compensator board within the instrument cluster…
